JohnBradley's 2.2 long rod build
Old Nov 24, 2009 | 11:18 AM
  #196
JohnBradley's Avatar
Old Nov 24, 2009 | 11:33 AM
  #197
ct78155's Avatar
Congratulations Aaron, very nice numbers.
Thanks again for your help.
___
Carlos Tirado
Tirado Custom Coatings
Old Nov 24, 2009 | 01:35 PM
  #198
RSMike's Avatar
awesome results Aaron!
this setup sure is inspirational.
Just a quick question, how come you tune it so rich? what are your tuning methods with fuelling?
I thought max power was about 12.5:1 AFR? (0.85 lambda ish)
Or have you done testing playing with AFR vs ignition timing and have found that you make the best power with around 11.5:1 to 12:1 AFR?
Old Nov 24, 2009 | 02:11 PM
  #199
Mike,
Between 11.0 and 12.0 it is a difference of 5whp with no other changes other than being leaner. Boost and timing, knock threshhold. etc. are all the same and the 12.0 only makes 5whp more. I tune to 12.0 on the dyno wideband which is at the tailpipe and is more like 11.5 in my in car
Old Nov 24, 2009 | 02:12 PM
  #200
___
Carlos Tirado
I owe you a couple cases of whatever you want Your piston coating is whats helping me out
Old Nov 24, 2009 | 02:27 PM
  #201
CMB's Avatar
CMB
Amazing power! Looking at the logs Im confused as to why the front o2 reads 0.72-0.76 range? Is it faulty?
Old Nov 24, 2009 | 09:17 PM
  #202
Good catch. IT was a new sensor, but when they get sprayed with coolant they dont seem to last too long. I dont use the NB to tune anymore anyway so as long as it keeps the CEL off for being stuck lean its okay. It cycles still for the little closed loop I have enabled so I havent bought yet another new one.
Old Nov 25, 2009 | 03:00 AM
  #203
CMB's Avatar
CMB
Yeah I figured..im still using the NB as my guide and shoot for 0.89-0.90. Do you know what that correlates to on the wide band?
I always find your posts most informative, but I am still wondering why your screen name is J.B. but your name is Aaron
Thanks Man
Old Nov 25, 2009 | 05:50 AM
  #204
Ted B's Avatar
13.0:1 - not good.
Old Nov 25, 2009 | 06:20 AM
  #205
CMB's Avatar
CMB
Originally Posted by Ted B
13.0:1 - not good.
Not true sir
Edit: This might be what you are seeing on your setup and possibly a faulty o2. I doubt this is where im at unless my car likes, no loves it that lean. Ill take Aarons word for it if you dont mind!
Old Nov 25, 2009 | 07:32 AM
  #206
Ted B's Avatar
Pardon me, I didn't realize you were looking at narrow band O2 voltage in a WOT log.
As for what it equates to in the way of WOT A/R, no one can give an accurate answer that question, simply because narrow band O2 sensors are increasingly inaccurate and unreliable as actual AFR deviates from stoichiometric.
Carry on ...
Old Nov 25, 2009 | 07:46 AM
  #207
Ted B's Avatar
Okay so here are the logs to correspond with the 2 dyno plots posted.
Do you have a log handy for any of the 570+whp runs?
Old Nov 25, 2009 | 03:22 PM
  #208
Ted,
Post 190 has the zip of all my runs the other night, enjoy
Old Nov 25, 2009 | 07:57 PM
  #209
Lucas English's Avatar
All done on pumpgas. Still no knock, but the spike and the 10:1 have me mildly concerned on 92 octane. I'll put up the logs when I get home for all to see
Old Nov 25, 2009 | 11:08 PM
  #210
Thanks Man
We actually shoot for .917-.936 (more on the 91 side). The name is explained in a thread in the NW section called who is johnbradley
Quick Reply: JohnBradley's 2.2 long rod build
