JohnBradley's 2.2 long rod build
Old Nov 25, 2009, 11:34 PM
  #211
JohnBradley's Avatar
For some reason the version of WinPep I have on my personal lappy is not working correctly and wants to chop part of the graph out. So for the time being its gonna have to be in speed with no torque. It does have Boost Vs Power though. All runs spiked about 2.5-3psi higher than it was at near peak power. On the old setup the boost was perfectly flat with no addl spike. The exception are the 563 and 568 runs which dropped back to 23psi just like the 570 run monday. I moved the 2.2 files to a new folder so thats why the numbers dont match up.
Old Nov 25, 2009, 11:48 PM
  #212
tonights data logs. The last one is the best one since it shows that knock V does not tell the whole story.
File Type: zip
Old Nov 26, 2009, 07:42 AM
  #213
FathouseFab's Avatar
Stop playing with pump gas, and let her eat!!!
Old Nov 26, 2009, 11:29 AM
  #214
I wanted to be able to drive it around on pumpgas for the weekend and it will go to corn next week. I had a 641/537 pull last night but not sure how repeatable it is so I left the low one up. Besides Chris and I have a friendly rivalry so I wanted to see what I could do on pumpgas. He was on 93 and a 9:1 2.3, so I figured we would be pretty close.
It's sad it took me so long to get it all working because now its going to end up as a dyno queen for the winter.
Old Nov 26, 2009, 01:45 PM
  #215
Screenshot of the log for any that want to look at it and not download them:
You also get to see why a voltage based knock system is worthless. The factory knock setting have been unaltered in my motor at this point. It is 5.5 though piston to wall, so its not the quietest.
I guess its 6* at 31.8 psi for that brief second, that might be reporting error from EvoScan but we do know it was at least 30psi. I am going to start revving it higher as well. The ultra long rod was a ***** to stuff in there with alloy rods but it seems to support high end power very well.
Here is the uncorrected number for last night as well:
The torque was 537.6 for the record.
Old Nov 26, 2009, 04:27 PM
  #216
A better version of the preceding dynosheet...this one has the RPM and torque.
Old Nov 26, 2009, 09:19 PM
  #217
PPX
PPX's Avatar
what a curve!!! mmmmmm
Old Nov 27, 2009, 04:48 AM
  #218
CMB
CMB's Avatar
I thought when I saw the 641 HP that was on corn..but on 92 is just wow! You must be ecstatic with the results Aaron, I would be. Have you driven this beast around? Hows the driveability on 92 with those 2150s? Thanks again for a brilliant write-up
Old Nov 27, 2009, 08:48 AM
  #219
The FIC2150s are high impedance Bosch based injectors and are like the ID2000s as far as drivability. Idle nice, cruise good, keep the fire fed at high horsepower, so all in all they win in my book. Yeah it is still on 92 octane pumpgas but it will be going on E85 before too long.
Old Nov 27, 2009, 09:09 AM
  #220
Evo8Emperor's Avatar
Hey Aaron. Here's a pic of my head. I remember you saying the valve chambers where worse on your number 1 cyl while mine was worse on 4. I left the last chamber on cyl 4 un touched so you could see it.
Heres a pictures of the ported chambers. There not smoothed yet but they look alright still.
Old Nov 27, 2009, 12:09 PM
  #221
RSMike's Avatar
Aaron,
what gear are you dyno runs done in? 5th?
Old Nov 27, 2009, 12:23 PM
  #222
Heres a pictures of the ported chambers. There not smoother yet but they look alright still.
Yeah thats pretty much what we have seen with almost all the VIII heads and a few of the IX heads. They seem to have coreshift issues in the VIII more to be sure. Bowls look good after you worked them
Originally Posted by RSMike
Aaron,
All runs are in 3rd and then a boost check in 4th on EBC equipped cars. I only tune diesels in 5th We have made 1-4 pulls on the dyno but I generally keep wheel speed limited to 100 or less in case the brakes on the dyno ever decided to go wonky.
Old Nov 27, 2009, 01:03 PM
  #223
ETS Michael's Avatar
Good Times! This car is a beast in person! I can't wait to see what it goes on E-85.
Michael
Old Nov 27, 2009, 01:23 PM
  #224
RSMike's Avatar
ok cool,
is yours a 5speed of 6speed gearbox?
i'm just wondering because your dyno figures will be "out" if you're in a gear that isn't 1:1. Because the gearbox is a torque multiplier. The closest in my car is 4th, which equates to 4.68 ratio, with my car having a 4.5 final.
Old Nov 27, 2009, 02:12 PM
  #225
Ted B's Avatar
It doesn't work quite that way. The gearing multiplies torque in the sense that it affects the amount of torque applied per unit of distance. Since the dyno isn't using distance as a measure of power, it's not so important.
Quick Reply: JohnBradley's 2.2 long rod build
