JohnBradley's 2.2 long rod build
Old Feb 11, 2010, 04:59 PM
  #271
BLKCarbonEVO's Avatar
Wow... a 2.1 that was somthing I was not expecting to read. Good luck and rev to the sky
Mikey
Old Feb 11, 2010, 07:40 PM
  #272
JohnBradley's Avatar
7900 wasnt what I was hoping for when it came to peak power.
Old Feb 11, 2010, 09:45 PM
  #273
dambikeracer's Avatar
John,
PM me what a bottom end like that would set me back?
Thanks!
Old Feb 12, 2010, 05:00 AM
  #274
crcain's Avatar
Is the peak power limited to lower rpm strictly a function of piston speed? Meaning faster piston speed = torque at lower rpm, and lower piston speed = torque at upper rpm?
I assume you want to drag race if your not happy with the torque at upper rpm. Is that correct?
What are you gonna do with your 2.2l?
I have to say, it's nutz how you don't need to rev a stoker. With my 2.4l on the road, I find I rarely go over 7.5k when driving hard.
Old Feb 12, 2010, 10:21 AM
  #275
CR,
Its a little of both. My 2.2 was 2235cc, peak piston speed was as you pointed out geared toward a lower powerband. The 2.1 reaches peak piston speed about 500rpm higher and being 2095cc it should allow the same turbo to reach peak VE higher and get me peak power at 8400 or so and then allow me to over rev about the same.
2.2 is slated for a customer car.
I do like the torque of the bigger motors, but I am a rev junky. If it doesnt rev like my bike I lose interest lol
Old Feb 12, 2010, 10:23 AM
  #276
Originally Posted by dambikeracer
John,
Thanks!
Sure
  #277
Force-Fed Performance's Avatar
Rev like my bike hahaha... sounds exactly like us
Old Apr 27, 2010, 09:59 PM
  #278
jdm602's Avatar
little birdie told me the new build is up and running. i think aarons out terrorizing the streets as i speak :P
Old Apr 27, 2010, 10:00 PM
  #279
So I hear as well... Who is this?
Mikey
Old Apr 27, 2010, 10:04 PM
  #280
R/TErnie's Avatar
His name is Jon. I know him...
I need to go for a ride in Aaron's new setup
I want to see Aaron pound the 1-2 shift @ 9500
Old Apr 27, 2010, 10:08 PM
  #281
O... It looks like Ty's old car or Shawn's with the 6262.
Ya I don't think Aaron will be going 9500 in this setup He is going to the moon!
Eric you know what it is right?
Mikey
Old Apr 27, 2010, 10:16 PM
  #282
jdm602's Avatar
nah its neither their cars haha.
prolly something rediculous like 11k.
Old Apr 27, 2010, 10:23 PM
  #283
Nope... You will just have to wait and see. I hope he does a built thread on his new motor.
Mikey
Old Apr 27, 2010, 11:24 PM
  #284
3gEclipseTurbo's Avatar
Mikey
12k?
Old Apr 28, 2010, 08:26 AM
  #285
Nope
There wont be a new build thread but maybe an update in the first post.
SO>>>>
The new 9:1 long rod 2.4 is up and running with 35 miles on it since last night at 11 (I woke up early just to go driving).
Specs-
Custom 9:1 86.5mm JE pistons (soon to have a part number and stocking status)
Stock 100mm crank
PE 1.2mm headgasket
ER assembled long block
The same Jeff Bush ported head
GSC 156mm steel rods
GSC Secret cams...all I will say is 12mm of lift
FIC 2150s
Further modified MIVEC cam gear
...more or less everything else is the same
There was some debate as to whether this is even going to dyno on gas or just wait till its broke in and go straight to E98. As much as I would love to rev this to 9500 the limit is going to be set at 8300 for this combo. Piston speed is a touch over 27m/s at that level so I will be content. I think the 2.2 was peaking at something like 31m/s which as I recall Eric telling me exceeds F1 piston speed.
Jon bought TJ's old ride.
Quick Reply: JohnBradley's 2.2 long rod build
