JohnBradley's 2.2 long rod build
#456
I have been looking and I think it might be more than some 67mm cars even, but it seems Dave has some cars that make more based on the dyno conversion. 93 octane might get me there but I am happy with what it does now.
#458
Thanks for posting those detailed logs on the previous page.
To me it's interesting how low the timing gets on these high powered cars, at around 5000 rpm, and how much timing can be recovered higher up the rev band.
Also the knock sum vs knock voltage is interesting.
In your logs the knock sum is always very low or 0, yet the voltage from the knock sensor goes pretty high in some places. There must be some tricky filtering or whatever in the stock ecu for converting the knock sensor signal to "knock sum".
This makes me wonder, what do you do if you are using a stand-alone like an AEM EMS, which I'm thinking just has an input for the knock sensor signal, and then you build your own table or something for knock retard from that voltage. I wouldn't know how to do that because what I see makes no sense!
#459
#461
Making power is never easy and since depending on how you wanna slice it we are either driving the equivalent of a 4.8L 1300whp V8 or 1950whp 7.2L motor (440cid)....ON PUMPGAS. Thats before we get to E85 and other race type fuels.
The process sounds more intense and time consuming than it is but its something that needs to be done regardless unless we have disposable income to toss at motors and headgaskets
aaron
#463
Well, I'm only about 200 mi away from you guys. Hopefully I'll get my car down there for something or other, one of these days. And hopefully it won't be rolling in on a flatbed!
