JohnBradley's 2.2 long rod build
Old Nov 3, 2009, 08:25 PM
  #121
BLKCarbonEVO's Avatar
Looks sick Aaron! Can't wait to see the before and after dyno! Did you use oversize valves?
Old Nov 3, 2009, 10:48 PM
  #122
JohnBradley's Avatar
On this one I used standard sized supertechs (inconel exhaust). I am pretty excited to see how everything comes together as well. Its been a long road but getting all the data prior took a bit and now I can compare everything back to back.
Old Nov 3, 2009, 11:04 PM
  #123
wshihdnevo's Avatar
Originally Posted by JohnBradley
Its been a long rod but getting all the data prior took a bit and now I can compare everything back to back.
Pun intended...?
Old Nov 3, 2009, 11:06 PM
  #124
I meant road Mr. Funny Guy
Old Nov 3, 2009, 11:15 PM
  #125
wshihdnevo's Avatar
i thought for a sec you meant to say it that way, keke
Old Nov 4, 2009, 10:52 AM
  #126
ETS Michael's Avatar
Started on the fuel system today as well. The Magnafuel 625 Pro Tuner pumps 5.3gpm...thats 318gph or 1200lph. Hopefully that will keep the FIC2150s in enough fuel to keep the 3586 fed.
That fuel system is intense...
Old Nov 5, 2009, 08:31 AM
  #127
Found some more pix of the head porting process:
Old Nov 5, 2009, 08:32 AM
  #128
Old Nov 5, 2009, 08:33 AM
  #129
Old Nov 5, 2009, 08:34 AM
  #130
That lip in the bowl area in the last 2 pix is the primary flaw in almost every Evo head I have seen apart. It takes alot of time and patience to smooth that out and get it to go away.
Old Nov 5, 2009, 01:22 PM
  #131
FathouseFab's Avatar
Yes it does, I have hours and hours in porting my head. I still think doing the combustion chambers was the worst part.
Fathouse
Old Nov 9, 2009, 06:51 PM
  #132
UPDATE---
Started it today after getting back from SEMA for the weekend. I didnt want to start it and then have to think about how I could be breaking it in and have it ready for the dyno. Right now it has 0 miles on it as we are waiting on one or two fittings in the engine bay that we managed to "make" to get it started.
Idles nice, doesnt like to idle on the trims with the magnafuel 625 as it over runs the return (feedline modded for use) and is currently at 58psi base. This makes the injector run as a 2550 or so. It will idle and drive in full open loop on gasoline though. The switch back to E85 and I will be able to turn the trims back on if I want to.
Might be my imagination but it felt more torquey just moving it around (first small stroker experience) the shop parking lot. More to follow, but its a start.
aaron
Old Nov 9, 2009, 07:20 PM
  #133
jid2's Avatar
yeah.........
Old Nov 9, 2009, 07:35 PM
  #134
I forgot to mention that the overrun was also with an Aeromotive FPR as well. Part of the issue was resolved by making a new siphon feed in the tank. I will be putting -6 return on I think to get it back down to sane level.
The pump is FREAKING QUIET. You hear it prime at start but even with my corked 3.5" (silencer in for street use) you cant hear it over the exhaust or in car and in car isnt that loud corked.
Old Nov 9, 2009, 07:59 PM
  #135
Congrats Aaron! Now get that thing on the DYNO!!!
Quick Reply: JohnBradley's 2.2 long rod build
