p0335 issue
p0335 issue
so i just rebuilt my motor and put it in the other day and when i went to fire it up it threw a p0335 so i replaced the sensor tried it again and the same thing p0335 and no start. i replaced the battery with a new one and the same result nothing with a code. help is greatly appreciated.
If you got a digital multimeter you can ohm the sensor (try all 3 combinations of prongs) if they all ohm to open there is a problem. I can't remember what the sensor ohms to but it will only be for 1 combination of prongs and at least not open wire.
If you got ohms then the sensor is good and either the trigger disk isn't triggering the sensor, really unlikely, or there is a wiring problem to the ecu.
okay i ohmed it out two were open and one measured 6 ohms so that is a good thing right? now here is another question on the sensor plug there are three wires positive, negative, and a signal wire. now when i originally tested voltage i went to the chassis ground and not to the sensor ground i got 12 volts on the positive and 5 volts to the signal wire. when i tested it to the negitive wire on the sensor itself i didnt get anything on the positive or the signal. is this normal or could this be the problem?
Pretty sure thats normal the hall effect sensors are pretty low voltage anyways. These sensors measure differences in magnetism in this case provided by the positive volt lead in and ground into a electro magnet and the change provided by the trigger disc.
If you got a pair of gator clamps you can ground the signal wire and trace it back to the ecu harness and see if she ohms out at 0. This will let you know if the signal is getting through at least.
ok but if there is 12 volts and 5 volts from the power and signal wire to the chassis ground but no voltage from the power and signal to the sensor negative doesnt that mean that circuit isnt being completed causing it to malfunction? if i am way off base please let me know **** even if i am right what am i supposed to do?
You really need a scope and some way to run metal across the sensor to see the voltage spikes. Here's a picture of what i'm talking about.
ok sorry for the misunderstanding, basically this is whats going on... on the sensor plug if i put a meter to the pos. and the neg. there is 0 volts. the same goes for the signal wire to the neg. 0 volts. now if i take the pos. and signal wires to another grounding source such as the neg terminal on the battery i get 12 volts pos and 5 volts signal. does that make more sense? thats why im asking if the crank sensor circuit is being completed and could this possibly be my issue? sorry so confusing.
Definitely sounds like the grounding wire (pin 40) on the ecu isn't grounded. Try ohming the ground to the negetive battery terminal it should ohm to 2ohms or less if not its open. Likely scenarios at this point are faulty wiring, unplugged ecu harness.
CIRCUIT OPERATION
• The crankshaft position sensor power is supplied from the MFI relay (terminal No. 4).
• Terminal No. 1 of the crankshaft position sensor is grounded with ECM (terminal No. 40).
• A 5-volt voltage is applied on the crankshaft position sensor output terminal (terminal No. 2) from the ECM (terminal No. 89). The crankshaft position sensor generates a pulse signal when the output terminal is opened and grounded.
For reference the sensor wire colors are:
Brown-Green (Pin 89 on the ecu) (signal wire)
Black (pin 40 on the ecu) (ground wire)
Red-Yellow (12 volt source from MFI relay)
CIRCUIT OPERATION
two wires? You just measured the plug and the battery right, and i mean the plug that plugs into the sensor not the sensor itself.
yes, i measured the black wire on the cas (ecu side) to the neg terminal on the battery and it read 0.L so with that in mind i am searching alldata to find the corisponding pin at the ecu i know you said pin 40 but i dont know which one that is once i find it ill test for continuity from the pin to the plug. is this the right course?
