Transmission diagram, top 3 bolts to engine block
I'm in the same boat right now. There are 5 bolts, 2 of the long ones, 2 of the medium ones and 1 short one. I'm pretty sure the short one is the lowest bolt by the firewall, and one of the longest ones is the lowest one by the radiator. Does anyone know where each are going? I thought I'd be able to eyeball it, but they dont all stick out of the trans evenly.
I took pictures of mine when it all come apart and the pictures i have shows a 60mm long bolt that goes through the block into the bell housing on the fron of the engine behind the front mount on the north south bar.
The 2 bolts on the top of the bell housing that go into the block are the same length
Then you should have a 40mm bolt that goes through the block into the bellhousing which you have to take the transfere box off to get to.
Heres the pictures i have which hopefully will help.
The 2 pictures i posted up are bolts for the back and front of the engine they are not both on one side.
Saying that though there is a bolt that goes above the 40mm one but from the bell housing to the block and that is something like 60mm long
Yeah, I understood that, so if you have a 60mm at the front and a 40mm at the back, and you said that the two at the top of the bellhousing are the same, then that leaves the last bolt which is another 60mm one.<---nice run on sentence. Which then would mean it goes above the 40mm one.
eusgen
Lancer Tranny/Drivetrain Tech
Sep 29, 2013 06:53 PM
okevolutionVIII
Aug 30, 2012 03:01 PM
