exedy twin plate clutch judder
I have a new exedy twin plate clutch on my 05 8 and after around 500mi it started to judder just a bit if I started slowly. I put it up for a week until my mechanic had a chance to look at it, I took it out to him and smooth as glass no jumping or shuddering. The next day I took it out to the mountains with my wife to drop the kid of a day camp. One mile on a gravel road and several miles of spirited driving and now I can’t engage the clutch without shaking the bolts out of the car.
Any Ideas?
Any Ideas?
after 500 miles, it should be sufficiently broke in. Unless a spring came lose on one of the discs allowing for excessive travel between the hub that mates to the input shaft and the actual disc friction material, no idea. These clutches have exceptional streetability and compared to others have very little to no judder.
I experienced something similar, but this was after several 1,000's of miles and the hubs on both discs were sloppy loose allowing for a lot of motion that shouldn't have been there, hence the judder. It's going to be hard to rule out the clutch without taking it out. What a pita.
Bump... I have been having a shuddering issue also. My Exedy Twin HD now has over 1,000 miles and I have been experiencing occasional judder when engaging in 1st gear and downshifting w/o rev matching. The otherday I was out driving the car hard for one of the first times since clutch install. After a few pulls I tried to downshift into a high RMP for the 1st time without rev matching and wow wut a mistake that was. I got such a violent shutter I thought my tranny was guna fall out. ouch lesson learned. Didn't rev match cuz I was engine breaking to slow down and come to a stop. I was thinking maybe it had something to do with the clutch fluid restirctor pill I had removed but I shocked the driveline pretty hard. not sure what to do at this point because I am used to driving the clutch now and I engage it consistantly the same but only get the shutter randomly when it wants to. If I tried I can get it to judder scary hard. Hoping it will go away on it own sooner than later.
Way to bump the old... good to know that someone else has this problem. Most of my issue resolved itself after the rock popped out from the drivetrain, but every time i down shift into first and sometimes into second I will get wicked shake. It dosent happen in any other gear I can jam into third at 100 no probs but second and first are shaky.
A rock in your drivetrain? This kinda scares me. Where exactly was is? Also do you think it was just an extended break in period? did it get better over time after a few thousand miles?
foxbear2277
Dec 15, 2013 05:49 PM
ninetails
65
Jul 20, 2010 10:42 PM
jer301
10
Dec 6, 2009 12:12 PM
