Stutter at 18 psi??!??
I'm hoping to get an opinion on my current issue. Long story short my EBC boost solenoid went out and I installed a MBC. Now when I hit 18lbs or more my evo starts stuttering and making a pff pfff pfff sound until it hits the mid to high range then starts pulling. I believe it may just need to retuned due to the fact that I installed a Walbro 255 fuel pump after I was base flashed by AMS. I noticed that while the car sputters im running rich (low 10 AFR). I have checked with some friends and they don't believe it's the spark plugs because of the smooth idle and it only does it at 18lbs and up in the low range. So could this theory be correct? Thanks in advance.
