crankwalk
Old Oct 22, 2009, 02:29 PM
whitemonster's Avatar
crankwalk
i was wondering if anyone has had any crankwalk issues in there evo? maybe i am being paranoid but i recently noticed a slight ticking coming from the pulley side of my motor. it seems like it comes and goes at idle but it definately ticks when the clutch is engaged. could it be something else since i just rebuilt my engine?
Old Oct 22, 2009, 02:33 PM
detroit pistins's Avatar
interested in hearing some answers! gl
Old Oct 22, 2009, 02:34 PM
o7'silvermax's Avatar
very rarely have evo motors crank walked i have only heard of one
Old Oct 22, 2009, 02:39 PM
any idea what the ticking could be? i have done some research and besides the ticking i don't really have any other symptoms. hell, everthing in the engine is new.
Old Oct 22, 2009, 04:54 PM
not sure if it matters or not, but i drained the oil and there is no shavings in the drain pan.
Old Oct 22, 2009, 05:02 PM
Armyevo2003's Avatar
What kind of clutch do you have in your evo? A very strong pressure plate can cause too much pressure on the bearing and give you crank walk. Had A guy over here in the quad-cities of illinois get crank walk in his yellow evo.
Old Oct 22, 2009, 05:11 PM
act 3200 its pretty basic i wouldnt think it is to much pressure
Old Oct 22, 2009, 05:14 PM
Draven83's Avatar
could it be your lifters?
Old Oct 22, 2009, 05:16 PM
and since the clutch is a pull type isn't it less likely that that would be the cause?
Old Oct 22, 2009, 05:17 PM
if you have the heavyduty pressure plate from act you should be ok, but the extreme plate they carry might be too much for your car if its only slightly modded and you have less then 400hp.
Old Oct 22, 2009, 05:19 PM
i thought the lifters too but ut gets louder when the clutch is engaged
Old Oct 22, 2009, 05:23 PM
If you are seriously worried it might be crank walk I suggest you take it to the shop and ask them. Its not really something to mess around with.
Old Oct 22, 2009, 05:25 PM
my mod list is balanced crank wiseco pistons, eagle rods, acl hd main and rod bearings, main studs, head studs, kelford 272's, ets intercooler and hard pipes, ported intake mani, injectors, and other little stuff. if it matters
Old Oct 22, 2009, 05:26 PM
no shops with in 100 miles of me
Old Oct 22, 2009, 05:53 PM
just checked to see if the crank pulley moves when the clutch is pushed in and there is 0 movement so i am assuming that is a good thing?
Quick Reply: crankwalk
