Getting past Emissions with catless tbe
be careful, each time you fail they might charge you
at least you don't live in CA
they're very uptight about emissions here so there are many checks and balances. even the results are immediately reported to the state so IF you had a friend working at smog check they couldn't hook you up
it may be the same in MD
in IL you have 2 tries i think after 2nd one they will direct you to drive
the car for inspection, they inspect entire car to find out why you cant
pass emission.
to all:
you have to drive the car for at least 80-100 miles so computer reads all the codes, worst ones are emmision codes that takes quite a bit...
you can have (one) code NOT READY. EVAP which takes even longer.
thats at least for IL.
DO NOT reset the code and go right away to emmision because you wont!
pass, read the code, check it, fix it. if you have no cat, get o2 bung.
this worked perfect on my car.
https://www.evolutionm.net/forums/ev...ouler-how.html
Excellent, thank you so much guys. A lot of good input here.
I am going to buy the o2 bung and install it then wait a couple days (100 miles) to get all the codes back then take it up and get it tested again.
-Randy
-Randy
in california, no cat= autofail. along with any other things they find upon inspection. of course, there are some shops that just pass the visual and go for the sniffer test. no codes, good emissions, you're golden.
