Getting past Emissions with catless tbe
Old Dec 9, 2009, 10:14 AM
  #31
dastallion951's Avatar
good luck tryin to pass the sniffer test...see my mod in sig, i run catless had two 18" resonators installed in my exhaust to quiet it down...and luckily i work for a shop so had a smog shop next door do a pre test now tuned with hks 272 cams i was off on my idle hc by about 20ppm....and at 2500 rpms i was off by about 40ppm hc....im runnin 880 injectors and a walbro 255lph. good luck if u wanna make power and if u wanna pass smog, id recommend a map switch
Old Apr 30, 2010, 08:35 PM
  #32
Dirty25RS's Avatar
slightly old thread that I'm about to bump.
Thought I'd share some of my experience with Ohio.
My Evo is on E85 and does have a high flow cat and the stock ECU.
1. I get P0420 CEL w/ or w/o fouler & recently Evap leak
2. The OBD2 forced inspection pass ECU reflash data didn't work for me, emission computer wouldn't talk to my ECU
3. Drove the car a little over 50miles, still wasn't 'ready'
4. Drove the car 230miles today, periphery bits for P0420 turned off, OBD2 forced inspection reflash is active, no CELS. I will go to emissions check tomorrow and tell you how it goes.
Old Apr 7, 2013, 08:13 AM
  #33
RpVilleneuve's Avatar
Got my emmissions notice friday.....guess ill keep my fingers crossed
sk13322
Jul 2, 2021 06:47 PM
evoluXrichie
South Region
20
May 11, 2017 04:16 AM
selayan
Lancer Troubleshooting
12
Aug 23, 2016 05:48 AM
03GTEvo
Nov 29, 2012 02:40 PM
deadbeatrec
Apr 5, 2008 05:28 PM
Quick Reply: Getting past Emissions with catless tbe
