car whines alot but runs good ideas?
I've had this whine at around 60 mph that gets louder to about 80-mph then dies off. Only when I'm on the gas, it goes away on Decel and when the clutch is engaged.
Anyways I thought it was the transfer case but It hasnt got louder and it's been over a year now. The car runs great and performs like it did day one.
So is this normal? I've seen videos of other evos on youtube and I hear the same whine but they have it the entire time. Is this normal?
Also in first gear the car whines like a SC...My 6 speed never did that but my shep 5 speed is a whinning bastard in first gear.
I'm honeslty to the point where if something is rattleing or whining I'm just going to ignore it and let it break so I know what to fix lol.
I think that overall the Evo seems to just have a noisy drivetrain. This is true of most AWD cars. That said someone who drives the car can tell when a noise is louder than it used to be and of course noises can be a sign of problems.
I have the 5 speed and I will tell you 1st gear is very noisy. I could be wrong but I suspect that it is straight cut like most reverse gears for additional strength. It sure sounds like it.
I also get a slight noise on decel in 4th and 5th. You can hardly hear it over the exhaust. I'm going to do a full fluid change and I'll report back if there's any changes.
You could try a full fluid swap on the tcase/trans/rear diff. See if it makes a difference.
just a neon
11
Mar 29, 2007 05:55 AM
