Coolant Smell
Coolant Smell
Just noticed that my ride isnt quite as powerful and when it does hit full boost its abit later then it use to. A few days ago, i got on it in 3rd gear 3k-6500. My brother following behing me said there was white smoke, and smelled sweet (Coolant Smell). Ive been looking every where for a coolant leak, but can seem to find any. Also when going down hill and leaving the car in gear, Vac drops to -22 (like normal) but there is a strong coolant smell that can be smelt inside the car. Even with windows up, and AC on or off.
Would this be a blown Head gasket??
I dont have any of the orther tools for a leak down test or anything like that, but besides the coolant everything else seems fine. Except for lifter tick, and missing bolt on exhaust manifold.
Any help would be much approved
Check the overflow reservoir dump tube. If there is coolant in there and/or its dumping coolant from the overflow - you have a blown HG. Reason: pressurizing radiator (blown passageway in HG) causing coolant to be pushed out.
Also check overflow for oil mixing in with the coolant and check oil for a milk shake like froth.
i dont understand why people like you have crap to say thats not helpfull and is some what rude...Ill never understand it...This guys probably worried and just looking for helpfull coments and not stupid arogant ones....Hope you figure out the isue and hope it isnt the head gasket but it does kinda sound like that may be it....good luck
Let's look at the key points of his post:
Just looking for extra thoughts. Thanks anyway
As for everyone else that is helping, No Milky fluid or discoloration. Rad Cap has good rubber for seal, so does the Rad Catch.
Whoa Whoa whoa guy.. im just asking a simply question. By the way. Boost Is fine. No leaks, No Coolant Leaks that i can see. No Compression test tool at the molment. Im sure my compression is fine. Still putting down 450 at 20 psi. Its not a major issue. i was just simply asking for thoughts, Im leaning towards my headgasket have a slight seal problem and already have it and plan on installing.
Mine had a small hole in it and I would smell coolant when I parked in the garage. I could never figure out what it was till it gave out on me one day.
Do you have to add coolant to the reservoir?
IIRC, when I went to my local dealer for a replacement, the parts guy said there was an updated version of the hose.
A better way to say it is the Car Runs Normal, Just has the Coolant smell sometimes after high Boost, and all the time when im comming down in and VAC is over -18. Usually when going down hill its -20 to -22. 5th gear 60mph
Check the small coolant lines by the turbo.
