Using port on Oil filter housing for FP oil feed line, now where do I put oil temp?
I am installing the FP oil feed line for my new Green 73HTA turbo. Problem is, I currently have two gauges right off the oil filter housing. (oil pressure and oil temp). Anyone know where else I can get my oil temp from? Perhaps I should focus on another gauge? Currently I have boost, oil pressure, and oil temp.
Look for the two pipe plugs on the cylinder head behind the thermostat housing. I believe that they access the camshaft oil passages. You should be able to use either of the two. Someone posted that the oil pressure is restricted in these passages, but they should be acceptable for oil temp.
Sorry to bring this back but I'm in the same boat. I don't like the sandwich adapter because it puts the filter closer to the ground which could be hazardous. I see 2-3 plugs in the head that could possibly be used but not sure which one to use. Any info would be great.
Like this:
http://www.suremarineservice.com/FIT-660.aspx
Oil temp fitting in the straight and oil pressure in the 90.
Like this:
Napa always keeps these fittings in a section and they always got em in stock.
