BLE solid tensioner
BLE solid tensioner
has anyone used the ble solid timing belt tensioner on their evo? i have one on my 1g talon and was wondering if it works as good on evos as it does on my talon or if anyone has ever had a problem. thanks
i have one. i dont really like it. problem i found is the timing belt gets tighter when the engines hot. so when its cold everything sounds fine but when its hot i can hear the timing belt making noise like its too tight. i think im gonna go back to the oem one. even though the last one i had failed and i was SOOOO lucky it didnt jump time. i guess if you finally get it adjusted perfect and checked your belt for excessive play like every month then you should be fine.
have you ever hand any stock tensioners give out on high hp builds...im doing a 10.1 motor with a twin scroll borg warner s300sx 83/75 i want everything to hold up btw is there any oil pump upgrades to get alittle more oil presser
anyone know what the tensioners used on the early evo's and dsm's are like compared to the later model evo? I have a solid tensioner on my evo1, it was on the car when i bought it and i never really thought to question it.
