Car won't start after I stored my evo 9 for 5 days.
Old Nov 10, 2009, 06:32 AM
Bom's Evo's Avatar
Its about that time for a new battery. 3-5 year lifespan.
Old Nov 10, 2009, 06:40 AM
meckert's Avatar
Earlier poster has the rt idea, either spark or fuel-- one thing no one has mentioned is the fuel--you can easily get varnish build up in you injectors from gas going bad clogging them--causing you to think you have little to no fuel. You have to put fuel stablizer in or something to keep that from happening if you store your car or it sits for any amount of time.
Old Nov 10, 2009, 06:52 AM
FutureNoob's Avatar
For 5 days?
Old Nov 10, 2009, 09:21 AM
EvoRob22's Avatar
True.
1) Always try to jump the car when starting it to rule out the battery.
2) Replace plugs if you want, but before you put the plug in the head try connecting the plug to the cop and putting the threads of the plug on ground (unpainted metal) and see if you have spark to the cylinder. If the plug sparks put them all in. If the plug does not spark you have a spark problem.
3) If the plugs don't fix the car and you have spark then your next problem has to be fuel. Make sure your fuel pump is running. If the fuel pump is not running find the fuel pump relay and make sure that is good. Then try cranking your car and hit on the fuel pump softly and see if it kicks on. If the pump kicks on when you hit it, you need a fuel pump. If the fuel pump still does not run, disconnect the connector and check for power and ground to your fuel pump. If you have power and ground and pump does not run, then replace your fuel pump.
4) If your fuel pump runs then something is blocking the fuel from getting into the injectors. It could be a fuel filter or clogged injectors. You would need to find out where the fuel is being stopped.
Good luck!
Old Nov 10, 2009, 06:05 PM
b0ricua_l0c0's Avatar
U Need To Get A Real EVO Not A Lacer And Try To Make It Look Like EVO, Lol.
Old Nov 10, 2009, 06:29 PM
buchnerj's Avatar
Spark. Compression. Fuel. Three things a motor needs to run.. You have to narrow it down. Check batt, check relays, check fuses. Its possible theres an obstruction in the fuel lines, but that would be a pretty rare problem.
Old Nov 10, 2009, 06:40 PM
FutureNoob's Avatar
no comment
Old Apr 3, 2012, 07:39 AM
alanarias22's Avatar
i have a similar problem right now..
the car started and when i stoped at a red light at idle the car shut off and wont start..
battery is good, it cranks fine but wont start. no misfire either..
what could it be?
Old Apr 3, 2012, 07:52 AM
silverguy's Avatar
check your fuel lines^^^ or your plugs
pennies_hatchie
68
Mar 5, 2023 08:02 AM
joehaugen
Oct 3, 2015 03:40 PM
scheides
May 28, 2015 12:01 PM
2high4u
Jun 3, 2014 12:22 PM
TRASHY_GTS
Toronto Lancer Club
Jan 27, 2012 02:37 PM
Quick Reply: Car won't start after I stored my evo 9 for 5 days.
