Repeatability of the Dyno Flash - long term study data and dyno sheet
#32
Originally posted by timzcat
I have only one thing to say:
Al has the customer service and answers his PMs
I was all signed up for the dyno day with Vishnu.
I was unable to reach Vishnu by any means so I decided it was better to have the support to back up the product.
#33
First of all I have respect for both of these venders, since I have read most of these threads on this forum and they do know what they are talking about, I think I would like to go with dynoflash when he comes to California simply because he tunes your car with aftermarket intake systems (I have RMR) where as Vishnu does not recommend intakes at all, if they did tune the car with intake then I would go with either vendor that comes down here and sets up a dyno tune day.
#34
Although an air filter upgrade can cause a lot of misreading on the MAF meter we find that with some fine tuning we usually are able to dial in the a/f ratio right were we want it - irespective of the type of intake used - although it sometimes does take a whole lot of work to get it dialed in with some of those cheaper intakes - they cause serious osilations in the maf signal
You are best to stay stock if you want your car to run well under all conditions
I use the RMR intake on my car and it is decent
For anyone doing a 300 whp and lower evo I recomend highly the K & N panel filter which gives all the benefits of the stock air box and which makes 5 whp over the stock insert
The ARC unit is another very good item which makes mad power gains but will prob break your bank account - I know Adam at Z1 auto sells them at a good price
HKS suction kit is great but makes most of its perceived gains by raising the a/f ratio by almost a full point leaner
#35
I'm the guy who's evo was tuned by al that gained 40+whp .....im super happy with the tuning and definately recommend it to anyone.....in my 6 years of hookin up cars this is by far the best bang hp wise for the all mighty $$$.....this is a definate must for everyone!
#36
I did not read through all the BS so forgive me if it has already been posted. So are you saying about the ECU mods piggybacks and reflashes that they stay tuned to the correct specs that it was tuned or does the ECU relearn it origenal mode. I am asking this because the post is about "repeatablity".
Thanks
Thanks
#37
How about sending one stock Evo to Al,one stock Evo to Shiv,specifying a certain amount of money,($4000.00) to be spent on each car in mods, for a daily street driven car that will last, and see which one produces a higher whp than the other, built to last car. Also needs to be done in a set time frame. 1-2 weeks.
#38
The Forums would be able to keep tabs on the progress of both cars with updates and dyno sheets. (using similar Dyno's). If either of you guys,Shiv,Al are interested, let me know. Almost like a Custom Bike Builder Build Off!
#39
Can someone refresh me on the ideal A/F numbers for the Evo8 please?
I think it's supposedly safe over 11.0 but under 12.0, right? I'm confused because on the graphs Al posted I couldn't tell if the a/f got richer or leaner since i wasn't sure which way was which.
Thanks.
Thanks.
#40
#41
Thanks.
Thanks.
Genereally we shoot for the 10.8 - 11.1 a/f range peak with a fat rich zone in the middle about where the car makes mag trq
#44
ok, and the danger zone starts when you get near 12.0 right?
A bit rich - but plenty of cooling fuel to keep matters safe
