Monster Sports PFX Intake kit
Has anyone install this on their USDM evo i want to ask if there is any sort of modification to fit this in the USDM evo with a stock hood. Also the will the map sensor be a problem installing this item because i am not sure but JDM evo doesn't have the map sensor am i correct? the Intake part
I dont see why this would fit under a USDM hood considering they are the same thing. As far as the map sensor is concerned, there should be an issue. The map sensor bolts onto the intake manifold as opposed to the intake...and JDM evos also have a map sensor. A nice one for that matter
thanks, i hope i am saying this right the map sensor is between the suction pipe and the filter.... the black box. I don't know if JDM has it or not wasn't really informed.
The reason i am asking if it fits or not because the other INTAKE that monster sells the carbon intake box you have to modify the hood some cutting in order to fit it with the stock hood unless you purchase the monster carbon bonnet.
Is there anyone that has this on their car that could get some in depth picture around the suction pipe thanks
razorlab
5165
Aug 11, 2024 07:56 PM
500whp.com
32
May 4, 2007 05:57 PM
