Clutch gone at 16k- Need recommendations
#32
I dont understand why most evo owners want a twin disk on a mildly modded car.Theres no reason for a car making less then 400ft lbs of needing a twin disk.its an absolute waste of money.I had a Comp stage 4 and it held 440+ ft lbs of tq. with no problem.
#33
With regard to your equality statment, your are saying a Quartermaster and Tiltons are better? In what way? I have heard they are horrible to drive and have very short life spans. F
Correct me if I am wrong, but the twins seem to get amazing life. I saw someone running <11 and got 35k out of it.
#34
You can go with a ACT HDSS, its rating is around 504tq and is around $625 on ebay and most shops. Look up the prices on the thread on socalevo.net. One vendor offers it for $550 shipped. Just my 2 cents, hope it helped.
#35
I assume you have a Competition Clutch Stage 4? How do you like the part overall? They have a reasonably inexpensive twin...
#36
I am probably going to avoid ACT. I have read and been told too many stories of high rpm lockout and other problems to seriously consider one. I would get a Fidanza at that point if I were going for high clamp single plate.
#38
I dont see it as a waste of money, I see it as a precautionary measure. On a mild modded car soon to be monster it is wise to get.
#39
Exedy Twin HD. I purchased from MAP for a great deal. I paid a local clutch guru $500 to install.
I have close to the same power as yourself. I went over the 500 mile break in on the Exedy Twin HD a few weeks ago and absolutely love it. The "ONLY" tiny complaint that I do have is the chatter. It is not extreme and does go away when good and warm.
#40
any kind of launching will MURDER single plate clutches. They can't take the heat.
The reason why the Exedy still has lockout issues (and it does) is because it has a large polar moment of intertia. (not just weight, but where the mass is located) IIRC the Exedy twin is around 32 pounds where as the QM and Tilton are in the high teens 17-19 pounds and have a super low PMOI.
The clutch discs are larger in diameter and there for are harder for the synchonizers to slow down... ESPECIALLY for the 1-2 shift. This is where the 7.25 clutches shine. The shift-ability of the Tilton/QM twin is far superior to the Exedy twin, but you're going to pay for it with harshness and noise. The exedy twin is the MOST streetable, BEST solution IMO. If you are serious about racing at all...I would get the Exedy Triple... or QM/Tilton.
You need more plates for more heat capacity and the more you slip the clutch to save your drivetrain...the more plates you'll need. I wish I would've got a triple or a 7.25 twin.
#41
twin disc is annoying to drive around with for a daily driver makes way to much noise... Depends what you want to use your car for... Ive had good success with act in two of my evos my last car was making 500whp 450tq on the hdss holding fine.. If you plan on drag racing and reving above 8k then go with sometype of a twin... although I am no clutch expert.
#42
In your experience, would I be happy with the noise, shiftablilty, and longevity of the twin HD on a daily experience? In terms of power plans, I would like to see 450wtq next year, so if you didnt think a twin would make me happy given the above, what would you recommend?
#44
if ur gonna race ur car hard, get a quarter master no doubt... also the fact they r in illinois is always a plus side
but in the case u want a act, my buddy has a BRand New Act Xtreme street clutch kit w/ a brand new Act Flywheel..
He sold hte car before he put this kit in..
I have another friends with this same clutch and he has never experienced any sort of lockout.
#45
I'll provide an update once I put some miles on it.
