How much power will my setup make [Mega Merge]
Old Apr 10, 2013, 06:33 PM
  #991
sofastsoreal's Avatar
fp red all the way its the happy medium between power and boost lag. you'd be able to boost more on the red and make more power the green has lots of limitations. if you have e85 then you can run a dual map and make some big power plus spool faster. i ran 342whp 91 oct and 432whp e85 all on the stock turbo
Old Apr 13, 2013, 09:40 PM
  #992
BEKevo's Avatar
Originally Posted by baysidemassive
Hi there,
Figured I'd post my setup and upcoming mods. This is my first post so thanks a ton for any replies
Evo 8 2003
Stock block
Stock 8 Turbo
HKS Racing Suction Intake
WORKS 269 Power Cams
HKS Downpipe
Borla Cat Back Exhaust
Halman Manual Boost Controller
Mitsubishi JDM MR Diverter Valve
Walbro Fuel Pump 255
ACT Heavy Duty Clutch
Stock Intercooler/piping
Stock O2
24PSI
What should this setup make?
I'm about to get my car tuned at FFTEC on a dual 91/E85 map. Also going to install FIC 1050cc's and a MIL SPEC 100 cell HFC and FFTEC Boost Solenoid.
How much should I be making when I've had the tune/injectors/cat done? E85 vs 91 Oct? I'd like to be close to 400hp. That'd be great for now. Any recommended items I should do, while I'm doing the other things too would be awesome to hear about.
Thanks in advance
Jamie
On 91 oct. on FFTEC's dyno (still a mustang dyno??) at your specified target boost level, 24psi, i think youd probably be around 330-340 whp.
e85 on the other hand....... Will for sure get you close or possibly above your 400whp goal. But at more boost, which is wold be safe on e85.. An intercooler upgrade would be beneficial at that point as well.
Old Apr 30, 2013, 12:16 AM
  #993
Evo_8_REDYG0's Avatar
First couple of mods im planning to do on my car since i got her about 4 months ago bone stock.
MAP "Short Runner" Tubular Exhaust Manifold
Perrin intake
ETS licp v2
Walbro 225
HKS Hi power Cat back
Tune
Thanks
Old May 5, 2013, 02:46 PM
  #994
OMGiiTzManny's Avatar
I'd like to see what numbers you guys think I could run. I'm on 93 Octane.
2.3L Stroker Block
Stock Head
Stock Evo 9 Turbo
Injen iC piping
Hks SSQ BOV
Upgraded intercooler
3" TBE
Walbro 255
1200 Injectors
Old May 20, 2013, 08:25 PM
  #995
hiboost2.0's Avatar
2.3L Stroker Block
Stock Head
Stock Evo 9 Turbo
Injen iC piping
Hks SSQ BOV
3" TBE
Walbro 255
1200 Injectors
Probably 370/380 On a dynojet. Your turbo is really holding you back.
Old May 23, 2013, 04:48 PM
  #996
Nelson999's Avatar
how much WHP you guys think:
stock block
Evo IX Turbo
ported manifold
Kelford 272 cams
GSC Beehive springs/retainers
Full bolt ons
FIC 1250cc Injectors
Walbro 255
E85 tune
Old May 26, 2013, 12:34 AM
  #997
alexeiyreina's Avatar
i have seem setups like yours making around 700 to 750hp but all depends,, make sure u get a good tune.
Old May 26, 2013, 12:37 AM
  #998
MANENERISM......i have seem setups like yours making around 700 to 750hp but all depends,, make sure u get a good tune.
Old Jun 4, 2013, 05:46 PM
  #999
R. Mutt's Avatar
Currently at 339whp/320 ft-lb@25psi with 91 octane on a dynojet with the following parts:
  • BBK Full
  • HKS 272 Mivec cams
  • Perrin Intake
  • Perrin 3port Boost Control Sol
  • PTE 780cc Injectors
  • Walbro 255
Injector duty cycle is 80% at its highest. Peak timing is 8* or 9* from my last tune with 1-3 counts of knock at most. I will be installing the following soon:
  • ETS 4" + Short Route Titanium Intercooler piping
  • Tial QR
  • ToxicFab v3 Stock Replacement Manifold (not coated)
  • Tomei Expreme Ti Cat-back
  • MAP o2 Eliminator (recirculated I.E. divorced) + DEI Titanium Heat wrap
  • STM resonated test pipe
  • Aquamist HFS-4 Meth Kit (will be spraying 100% meth)
I will be looking to go no further than 26psi for now until I do head studs. My guess is 400-425 whp/380-400 ft-lb range
Old Jun 5, 2013, 09:20 AM
  #1000
Werdna06's Avatar
How much boost is safe with a stock block with arp head studs?
Old Jun 5, 2013, 04:38 PM
  #1001
R. Mutt's Avatar
I've read on the forum that people have gotten away with figures of 30+ psi on stock studs. They say it's dependent on how good the tune is. Suffice to say your tune better been knock free.
https://www.evolutionm.net/forums/ev...ds-27-psi.html
Originally Posted by JohnBradley
No you dont need studs, unless you are planning on doing a headgasket job.
Its more a bad tuner thing.
As mentioned the sea of 8s doesnt help detonation or cylinder pressure and was causing HG issues. Jeremy, you have run how much on stock head studs? 33-34psi? I have run as much as 36psi when my car was stock motor (and headstuds) on E85, we ran 38psi on Jakes, and I made 574 on pumpgas on stock headstuds.
Old Jun 5, 2013, 08:58 PM
  #1002
U will never know till u put it on a dyno but with that setup u will be around 600 to 700 on e85 with a good tuner on 30 psi of boost
Old Jun 7, 2013, 12:31 AM
  #1003
Thugline's Avatar
How much will I make on an Evo 8 on stock bottom end with this setup?
Br tbe: $880
Quarter master twin disc clutch
Cosworth m2 cams:
Full blown fuel pump
Ets 3.5" fmic w/ic piping and Tial bov
Map ef4 turbo
Toxicfab forward facing mani,licp,02 dump
Rc injectors 1600cc
Battery relocator kit
Tunning 91/e85
Map3 porting I.M.
milspec throttle body+shaft seals
Spark tech ignition
Half size radiator
Old Jun 11, 2013, 09:45 AM
  #1004
yankeefan1990's Avatar
Originally Posted by stryfetew
6265 same as the 850r? I'd say 600-750whp. On race gas of course.. 500ish on pump.
^ +1
Old Jun 12, 2013, 09:35 AM
  #1005
R. Mutt's Avatar
Still no guesses at how much I will make?
Quick Reply: How much power will my setup make [Mega Merge]
