FP Black going on my Dyno Queen
Old Dec 9, 2009, 08:53 AM
  #61
Tony1's Avatar
What most people don't seem to realize is that there is always fuel pressure pushing down on the injector, the injector staying in place isn't a result of the rail pushing down on the injector. They are not too tall, they are the exact length oring to oring as the ID1000's for the EVO, which tons of people have used with no fitment problems.
The ID adaptor tops also incorporate a replacable filter which will minimize problems with trash ending up in the injectors. FIC does not.... yet....
Old Dec 9, 2009, 10:41 AM
  #62
Steve93Talon's Avatar
I understand that fuel pressure is what keeps the injector down, but you have to realize that (mis)perception can become reality, and if someone's injector is loose and able to be lifted out of it's lower seat, that can be a little unnerving.
Also, you have to take into consideration that alot of people, especially at the power level where 2000cc injectors are required, perform boost leak tests religously. You can see where the problem is there.
As for the height, I've not personally seen them side by side with the FIC so I can't comment further, I'm only relaying what I've heard from someone who's used both.
The filter is a valid point but again comes down to theoretically better vs. real world. Could there be a benefit if something gets past the inline filter on the feed line? Sure. Have people been getting along fine all these years with injectors without a filter built in? Yep.
I think now that FIC has started offering these injectors for less money, you're in the difficult marketing position of proving that the ID version is "Better enough" to justify the cost difference. In the case of this thread, the car is showing great results with the FIC2150s.
In the spirit of not taking this thread off-topic any more than we have, I'd suggest starting a new thread with your test data and, ideally, some real world back to back testing showing why people should be considering the ID option. There's no such thing as too much information, and I think people would appreciate anything you put out there to help them make the most informed decision possible.
Old Dec 9, 2009, 02:25 PM
  #63
Tony1's Avatar
Seriously? Injector Dynamics has put more information out there than anyone. I would think it would be the job of those claiming to have 'the same thing' to show it. FIC has hardly any information out there about these injectors, just riding on ID's coat tails with the following that has been created by the testing and data done to bring these to the market.
Old Dec 10, 2009, 09:09 AM
  #64
JohnBradley's Avatar
That would be cool. We have used both in 2 different cars. We swapped the FICs from mine to Luke and back. I posted data in this thread:
https://www.evolutionm.net/forums/ec...0cc-notes.html
The first page has all the relevant data as far as IDCs at a given airflow/power level. I think you are suggesting a different kind of test, but in any event a seperate thread would be a good way to keep data clear and unmuddled.
JohnBradley
ExtremeTurboSystems.com – WA
119
Jun 2, 2011 06:42 AM
Lucas English
May 15, 2010 07:37 AM
Lucas English
Jan 31, 2010 05:53 PM
JohnBradley
May 12, 2009 09:25 AM
Lucas English
Aug 28, 2008 07:27 AM
Quick Reply: FP Black going on my Dyno Queen
