excessive amount of smoke from exhaust
Old Dec 12, 2009, 05:41 PM
  #31
bigturboevo80's Avatar
compression test the motor.
Old Dec 12, 2009, 05:50 PM
  #32
meckert's Avatar
ok, if you have wht anything in the oil--its water so you have a blown head gasket--compression test wont tell you that as you discovered. ( unless you have a big gasket issue) - pull the head have it milled flat replace. case closed.
Old Dec 12, 2009, 06:00 PM
  #33
shh!! sleeping's Avatar
boost leak?
Old Dec 12, 2009, 06:13 PM
  #34
evosam726's Avatar
im at your same spot =\ well good luck on the fix
Old Dec 12, 2009, 06:31 PM
  #35
BLKCarbonEVO's Avatar
Check your shaft play to verify your turbo is not going bad. If you are losing oil pressure (the reason your light is coming on) you are destroying your rod bearings... not good.
Mikey
Old Dec 12, 2009, 07:31 PM
  #36
05ah8james's Avatar
If it where valve guides like suggested there would be some nasty sounding tapping noises going on. I just had this on my car.
My bet is on the Headgasket like others on the board. I have had headgaskefs go on other cars, and this sound like the same thing I was experiencing. I did this to one of my cars because I was having a hard time identifying if I had a bad headgasket as well.
Set everything to TDC and take a spark plug out. Shine a light in the hole and of it is intact the headgasket, you will see small droplets of water sitting on the head of the piston.
Goodluck.
Old Dec 12, 2009, 07:37 PM
  #37
If it was the head gasket chances are there is coolant in the oil. He didn't say there was coolant in his oil.
Mikey
Old Dec 13, 2009, 02:19 AM
  #38
haseeb's Avatar
Originally Posted by bbyevo8u
my car has been smoking like crazy before warm up but when it does warm up the smoke is 95% gone??
wtf is going on here!
im having the same issue ..
did u find the problem ?
nybody gona help us to find where the problrm is ?
Old Dec 13, 2009, 07:01 AM
  #39
Charlie-Y's Avatar
Already did the test, standing from the front bumber , left to right reads,
180
180
182
182
Anyways, gonna have a oil pressure check by a mechanic this weekend, hopefully.
aguita
Mar 24, 2009 09:55 AM
Evolessfornow
20
Mar 18, 2009 09:28 AM
Fireball
36
Apr 26, 2007 10:47 AM
rcheung
Nov 5, 2006 08:40 PM
App420
Aug 13, 2006 09:24 PM
Quick Reply: excessive amount of smoke from exhaust
