what do 880cc injectors max out at??
i just bought an ported fp-red and some other stuff along with 880cc injectors now i'm thinking i should have went with 1000cc?
i dont think ill run any other gas besides pump 93oct for a while but just in case i want to run c16 or meth ill need the 1000cc's rite?
so what does the 880's max out at- whp/boost?
heres a pretty good break down of injectors....
End all: "do i need a fuel pump/bigger injectors?" thread
Here's the math for you, just in case you don't what I am referring to:
880cc/min injectors
4 injectors = 3520 cc/min fuel
specific gravity of gasoline (.73-.76, .74 commonly used)
3520*.74=2605 g/min fuel
2605g/min fuel / 454 = 5.73 lb/min fuel
So, what AFR are you going to run? 11:1? 11.5:1?
At 11:1:
5.73lb/min fuel * 11 = 63 lb/min airflow
FP states the Red is a 60 lb/min compressor. So, yes, 880cc injectors should be able to support a maxed out red on pump gas, assuming that your fuel pump is up to task and the injectors truly flow 880cc/min. But as you can see, it will be close. However, you probably won't be able to max out the red on pump gas anyway. So, you should be OK.
My opinion...get a fuel setup that can handle a maxed out Red on E85. Proper injectors and fuel pump (dual pumps). That way you only have to go through it once and be done with it.
880cc/min injectors
At 11:1:
