Clutch or trans mount vibration
I just installed my Exedy twin disk (PITA) and also installed AMS trans mount bushing. I noticed that if Im at a stop and rev the engine I feel a vibration at around 2K rpm. Is this from the mount? It does it with the clutch pedal in or out. Also if im crusing in a gear with the engine speed at 2k I can slightly feel the vibration. If Im coasting and push the clutch pedal in to rev the engine I dont feel the vibration. Im hoping this is normal with this mount and its not a clutch problem. I also have AMS front mount along with the Ingalls stiffy mount. Let me know your thoughs or if you have any questions. This is why I hate to do 2 mods at once
If the chattering noise is what you are talking about, then its perfectly normal on Exedy Multi-plate setup. Go with the BLOX front engine mount will help eliminate notchy shifter feel. BLOX mount was probably the best bang for the buck mod for EVO VIII/IX. Especially during Clutch install. Throw it right in and you will feel a big difference.
No its not a chatter its a vibration. Feels like something is out of balance. Its probably just the mount making me feel the vibration now. I will see what Ams thinks since I will be stopping by there this week.
I removed the stiffy mount and it seems to be about the same. I will see how it is after I install the cam side AMS mount. I also noticed its a little more noticable when its cold outside like in the morning. This leads me to believe it is the mount.
Let me say this, I replaced all three mounts ( left the back one alone) with urethane. Just the frt mount had vibrations everywhere, after adding both sides in combination with the front even with a split duration 272/264 hks cams advanced at +2 ,vibration is less then stock for me.
johnnnyjeans
Jan 1, 2013 11:39 PM
tehforbes
Dec 28, 2006 07:22 PM
Smogrunner
23
Oct 23, 2006 04:30 PM
