gt35r vs 6265 (help)
gt35r vs precision 6265 (help)
can anyone do a comparison between these two turbos? which is more powerful. which spools better? any dyno graphs? what do u recommend?
6265 is equal to which gt series turbo?
waiting for replies
waiting for replies
there is no comparison.
a 35r is a 65lb/min compressor w/ a 61mm turbine.
6265 is a 72lb/min compressor w/ a 65mm turbine.
6262 is more similar to the 35r w/ it being a 62mm compressor and turbine wheel (compared to the 61mm comp/61mm turbine of 35r)
not to nitpick, but a simple 2min search would've brought this up since the 62mm series is widely discussed and compared on here.
Here are quick answers: The 6265 will spool later but make a boatload more power. The 6265 is unnecessary for an Evo, use the 6262 instead. The 6265 is not really equal to any GT series, the compressor will make more power than a Garrett 67mm, and the turbine is similar in size but better than a P trim.
CrashD
33
May 12, 2010 12:52 AM
