evo 8 to evo 9 maf
although i don't have a 9 maf sitting here in front of me right now, i'm pretty sure it is the same part number. therefor yes they are interchangable (with no scaling required). the maf scaling tables are different because the heads flow differently so they need different scaling for idle. this is unconfirmed until i have a 9 and 8 maf in front of me though.
NO NO! Don't remove your honeycombs either. Removing them messes with airflow across the sensor. You are far from maxing out a stock VIII maf w/honeycombs installed.
And no, there's no physical way to tell them apart other than the serial # on the maf.
i understand your point but im afraid my turbo might sucked part of it
