Main studs - Align boring really necessary?
Old Jun 11, 2010, 11:47 AM
DarksideZ's Avatar
Originally Posted by wreckleford
Absolutely necessary to align hone, or to check clearances?
Both.
Old Jun 11, 2010, 03:08 PM
icantdrive75's Avatar
Year old thread, fyi.
This is debatable, but I'll have to say no, it's not necessary. The clamp load increase does have the potential to distort the housings. But my bearing clearance and endplay remained the same when I switched from bolts to studs.
You don't have to run oversize bearings when you align hone a block. They cut the caps first, making them shorter, so you end up with the same size hole. It's not like machining a crank.
As long as your measure your clearances properly, you will not have any problems.
Old Jun 11, 2010, 07:04 PM
LCS
LCS's Avatar
I searched a lot and couldn't find any specific thread with all the concerns.
Tomorrow I'll clean the block and torque the main girdle and the torque plate, both with studs. I'll check the main bores for any distotion with a dial gauge. Next, I'll assemble the crank with bearings and check misalignment with plastigage.
Old Jun 14, 2010, 02:08 AM
Didn't realize this was your thread do with it what you will.
Any results for us?
Old Aug 4, 2010, 11:02 PM
LCS
LCS's Avatar
Measured it today. Main bores horizontal axis is smaller by 0,02mm, or 0,0008". Plastigage showed 0,04mm clearance on vertical axis.
Dunno if I'm align boring it. I'll do the cyl bores and then check all again.
Old Aug 5, 2010, 11:48 AM
Paul Walkin's Avatar
Why not use stock mains?
Old Aug 5, 2010, 03:59 PM
LCS
LCS's Avatar
Engine´s intended for road racing.
Old Sep 2, 2010, 11:51 AM
DOUGLAS's Avatar
How vital are ARP main studs? I purchased a set but the machine work was done without keeping this in mind. So I decided to just stick with the stock mains.
Jackson Machine
117
Jun 4, 2015 03:45 PM
Craig King
11
May 19, 2011 07:11 PM
LCS
Aug 27, 2010 10:21 PM
AutoMotoSports
Automotosports - Illinois
10
Dec 29, 2009 01:26 PM
BLKCarbonEVO
27
Oct 23, 2009 08:31 PM
Quick Reply: Main studs - Align boring really necessary?
