Part Number Request - Shifter Linkage White Plastic Clip
I am in the process of installing a new clutch. transmission is back on but i seemed to have misplaced this white plastic clip part encircled in yellow:
if anybody has one knows what its called, or better yet the part number i would greatly appreciate it.
Here is a picture of when i lost the plastic clip, and the yellow circles are where they are suppose to be.
It is a 5 speed 05 evo GSR -
Shep Rebuilt
Thanks,
John
Shep Rebuilt
Thanks,
John
Bringing this one back as I have not been able to locate this part number or much information in general. The clip pictured below broke when reinstalling the transmission...its the small plastic bushing between the shifter linkages.
Thanks.
Thanks.
if you are talking about the bushing inside the metal ring of the shifter cable then i suggest just simply upgrade to something like this. http://www.maperformance.com/torque-...s-scb-00x.html
^Nope, I already have shifter cable bushings. When looking at the picture, it's right next to the black cap on the shifter assembly...you can just see the broken piece of white plastic.
This it?
https://www.evolutionm.net/forums/ve...ll-review.html
If so, I believe you can't buy it separate, its part of the rocker arm that connects to the transmission. Maybe if someone can name the part, call up mitsubishiparts.net to see what they have. Sorry, I couldn't find the name of it anywhere I checked. Good luck.
Links for Evo X but believe that piece is the same.
Did you ever found out what that piece is called or what you need to get that comes with it? I have a Evo 4 that i recently did a engine swap on and i guess i didnt put that piece on right because it fell off while i was driving.
chargespeedMR
For Sale - Cars For Sale
26
Jun 12, 2014 12:41 PM
Jtoys
16
Mar 5, 2012 07:27 AM
