Cat on for emissions and running lean!
1 Post
check the boost, turn it back down to 21psi peak and log again to see if the AFR drops from the 12's to the 11's again.
correct, not enough fuel supply can be due to the fuel pump or injectors being too small for the amount of power you're trying to make. IDC's over 100% mean the injectors are completely maxed out and when boost is increased it cannot supply any more fuel for the added air, this causes the lean condition. It might not be his issue, just a hunch.
also would i be okay running 880s until FP red in the summer?
1 Post
im running 26-27psi (weather depending) and im on stock injectors. they are usually between 98%-103% (again depending on weather) when i log the car and it causes knock up top. i was thinkig about picking up a set of used 680 injectors until i get my 880s (or maybe ill just go buy 880s now?) so i can solve this 100%+ IDC problem. would i have to get completely retuned for a set of new injectors or could i just adjust my fuel trims and injector scaling for the bigger injectors?
about 110%+ is where I usually notice I'm adding fuel and the AFR is no longer getting richer which forced the IDC up even further.
1 Post
yep, he lowered the boost to 20 and the AFR dropped to 12.5 and it's not out of IDC. I'm not sure why it's doing this, I had him check the FPR hose etc...and everything was fine. I'm adding some fuel in the tune to see if we get an improvement or just more IDC
im stuck at 12.08 at the track (averaging 1.69-1.75 60 footers, stock turbo, 93 octane, 26psi). would it be so horrible to turn up the boost to say 28ish just at the track for a few runs to break 11's? would turning the boost up cause so much knock to cause the ecu to pull enough timing to end up slower and less hp than i was at 26/tuned (if that sentence made sense)? sorry off topic
1 Post
1 - lean out the AFR due to inadequate injectors
2 - move you into a different fuel and timing column that the car wasn't tuned for potentially causing further issues
the short answer is that it's a very bad idea.
