headgasket. =(
Old Dec 15, 2009, 12:02 AM
Lancerguy'03's Avatar
headgasket. =(
so 64xxx miles and my head gasket gave out....
32psi on FP Green (stock block) running 30psi for like 30,000 miles so i cant complain to much...just sucks...thought i would share.....
im doing stock head gasket with ARP head studs now....and contemplating port and poshing the head....but thats another $600 or so....so i duno (probably not)
oh and I just replaced the water pump and thermostat yesterday....
FML.
expensive week.
Old Dec 15, 2009, 12:13 AM
tim85851's Avatar
is there any reason to not go with a cometic head gasket instead?
Old Dec 15, 2009, 12:28 AM
i asked about that....and my tuner said the stock gaskets are as strong as after market ones.
this is just one of those things that happens randomly...cause a guy running similar set up has 107,000 miles and at least 20 track days and still on stock gasket...and my tuners car has 80xxx miles with a 35r @ 30psi and still stock motor. im sure there are many others.
but if someone can chime in and explain why an after market head gasket is significantly better....
just for reference stock gasket is $60 and Cometic is $95
Old Dec 15, 2009, 12:30 AM
tim85851's Avatar
yeah id like to know too...
one would think that an aftermarket company such as cometic would be a better choice then going back to the stock gasket...a lot of my DSM friends swear by cometic...
BUMP for some responses!
GSX_TO_EVO's Avatar
did you have the ARP head studs before?
Old Dec 15, 2009, 12:33 AM
no...my block was completely stock
Old Dec 15, 2009, 12:42 AM
GSX_TO_EVO's Avatar
Well i would assume that was the issue, I would just go back ARP headstuds and a OEM headgasket
Old Dec 15, 2009, 06:10 AM
grillpt's Avatar
I had to pull the head on my car. I went with the oe headgasket and ARP studs when mine was done. Personally I think oe is fine, up to you though.
Old Dec 15, 2009, 06:19 AM
Sharkbite2000's Avatar
OEM in my car and never had a problem yet "Knock on wood"
tweakdsm's Avatar
oem is not bad at all. i had stockblock with head and hta35r, regular 35r - 20g, motor gave out at 102k miles. still headgasket was fine
go with oem,
Old Dec 15, 2009, 09:27 AM
Evotech8's Avatar
There was a thread a while back a shop did a comparison of evo head gaskets including cometic...
Stick with stock unless your doing mega boost.
Old Dec 15, 2009, 09:36 AM
05blue8's Avatar
I think even the big horsepower guys run the stock also, PM mike at awd or buschur
Old Dec 15, 2009, 09:49 AM
BBS
BBS's Avatar
If you search the internet, you'll see pressure film testing done with cosworth, oem, and cometic head gaskets on the 4g63. The cometic was absolute trash compared to the oe and cosworth. I think the article was on motoiq.com
Old Dec 15, 2009, 11:55 AM
mega-z's Avatar
+1 for oem headgasket!
Old Dec 15, 2009, 12:26 PM
jid2's Avatar
OEM or Cosworth for sure.
Quick Reply: headgasket. =(
