Where to dent on the DP to clear ACD
I will be installing a new downpipe on my EVO 8 (ACD) this weekend because I am having issues of the DP hitting the transfer case.
Putting a dent in the DP seems to be an option to avoid this problem. However, I am not 100% clear on where to dent it.
Here are a couple links with different views. I do not know how to upload photos yet, because I am just getting used to my new MacBook Pro...If for some reason they do not open just google search "evo downpipe" and use the pics that are designed for the ACD...
http://www.jscspeed.com/part_pictures/cobb_evo_dp.jpg
http://www.jscspeed.com/part_picture...9_downpipe.jpg
Can someone maybe paint shop it and circle the area where it should be dented and repost the image in a reply?
Thanks so much for your help!!
-Cheers-
-Cheers-
My Megan fits just fine too. I put a couple washers on the tie bar because after a couple weeks it started to rub. Very easy fix and no issues otherwise. I had the flange of my TP rubbing on one of the heatshields at one point, which I thought was the DP hitting the tie bar again. Bent the heatshield back a bit and problem solved.
I wouldn't just automatically whack a big dent in my new DP. Put it on and see if it rubs first. If it does, find out where it rubs for sure before you go denting up your pipe. It could rub in some unlikely places and just need some simple adjusting.
JSC Speed
Evo 'For Sale' Exterior Styling
58
Oct 28, 2008 07:57 AM
JSC Speed
Jul 10, 2008 06:03 PM
Speed Element
Sep 29, 2006 07:05 PM
