All 3 ACD lights lit at the same time?
I have been having all three of my ACD lights being lit at once on and off for a while now. After reading through many posts, it seems I am not alone. I discovered an odd thing that I wanted to share and see if anyone else was having the same issue.
When I use my wipers, I get the three lights at the end of the first downstroke of the wipers. Hot, cold, wet, dry it doesn't matter. They will stay lit until I turn the key to off and restart the engine. Everything being the same, if I reset the car and do not use the wipers, the one light indicating my ACD selection will remain lit as it should. I can drive all day or two minutes, when I use my wipers, I get all 3 lights.
Anyone else?
Any suggestions?
Anyone else?
Any suggestions?
The only connection i can think of is the electrical gremlin of water in one of the connectors. Maybe this is a far fetch but the only thing connected both to your wipers and ACD computer are the crash sensor cables running through the same connector as the wiper cables.
https://www.evolutionm.net/forums/in...s-how-fix.html
I hope that this helps...
Hmmm, I will have to look at that. Thanks for your thoughts on this thing, I have had a couple small electrical issues with the install of my AEM stand-alone, maybe as that gets cleaned up I will look at those other sensors and find the problem.
rmatt8748
14
Jun 2, 2007 07:24 AM
