Minimum mods with FP Black?
Old Jan 7, 2010 | 07:01 AM
  #61
94AWDcoupe's Avatar
Originally Posted by batty200
Here is a results thread created by AL with a similar but less modded car than yours with stock block and the power it was able to make still on stock clutch. I dont think you will be near these results with the route you selected. The turbo first is a great idea.
https://www.evolutionm.net/forums/ev...h-458-whp.html
actually that thread is perfect example of why not to use black on a lightly modded setup. those are extremely lackluster results for a black turbo.
Old Jan 7, 2010 | 09:05 AM
  #62
matt55's Avatar
400+ WHP with stock cams(evo8 ?) , 93 oct and only 20-21 psi
Old Jan 7, 2010 | 09:12 AM
  #63
scheides's Avatar
EvoM Moderator
+1, it seems as though TBE, cams, FMIC, LICP, fuel pump, injectors, etc should be the minimum, as long as SS o2 housing and a ported exhaust manifold are put on at the same time as the turbo. The numbers are not that spectacular, I made more than that with my BBK at 24psi and have over 500rpm of more torque
Old Jan 7, 2010 | 10:37 AM
  #64
mayberry's Avatar
I know you're not looking for other opinions but from the sound of what you're looking for I think the CBRD BBK Full is right up your alley. Just something you may want to think about.
Old Jan 7, 2010 | 01:03 PM
  #65
94AWDcoupe's Avatar
problem is people read a peak HP number and get all goosy. they dont know how to read a curve and relate to how the car will actually pull when driven.
Old Jan 7, 2010 | 06:30 PM
  #66
batty200's Avatar
You made more power at higer boost. 500rpm is a small amount of lag especially considering the ultimate power potential of both turbos. For the time being 450+whp on a stock block until he adds more mods and replaces his clutch is rediculous. Imagine if his clutch would have held and he could have ran 24psi like scheides and that is with STOCK CAMS! You guys on here are so backwards it is retarded. Have fun with slow cars.
Old Jan 7, 2010 | 08:37 PM
  #67
Teal2nnr's Avatar
Not going to read through this whole thread, High boost and not much money don't go hand in hand.....by the way this frist page looks, i hope that you stay away from the black and get something more manageable.
Good luck.
tephra
Apr 5, 2021 06:30 AM
51
Oct 18, 2016 12:43 PM
leo_99
Apr 26, 2016 08:49 AM
tscompusa
Jan 13, 2016 03:22 AM
Dallas J
293
Oct 9, 2015 11:23 AM
Quick Reply: Minimum mods with FP Black?
