Clutch is HARD!
Clutch is HARD!
Alright, well from my last threads my slave cylinder was broken but i got it fixed. Well after bleeding my clutch. My clutch is REALLY hard now anddddd i dont know what is wrong with it. It seems as if i have a aftermarket clutch now. Cause trust me ive driven aftermarket cars before with hard a** clutches. LOL! Or do you guys think its just like that?Or is my clutch going out?
It sounds like the broken slave cylinder was merely a symptom of a bigger problem and it was probably broken because your clutch is so hard to disengage for whatever reason.
Are you the original owner? Do you for sure know what clutch is in there?
Everythings good. Just when you slip the clutch up, its harder to balance to not kill the engine as those good clutches when your in first gear letting the clutch up it balances out with the gas(gas pedal) and releasing it but mines you have to let the clutch go up higher before it starts rolling.
