DIY COP. anything to worry about when selecting coils?
Old Jan 1, 2010, 07:20 PM
  #31
norcalSRTrida's Avatar
odd. its going to do that if i copy/paste. sorry bout that.
just type in 2003 chrysler 300m thru the search and go to electrical > ignition system > and coil
or: http://www.trademotion.com/partlocat...layCatalogid=0
you will need for the 300m coils:
Connector housing: p/n 90980-11246 (4 required)
8 Connector wires: p/n 82998-12440 (8 required)
i will update post 1.
ive also read that k20 coils are awesome coils. they run about $80/coil though...which can get pricey. CBR's run about 45-50/coil, and 300m's about 30-35
30520-PNA-007 is the K20 coil
Old Jan 1, 2010, 07:46 PM
  #32
updated post #1!
Old Jan 1, 2010, 08:10 PM
  #33
RSMike's Avatar
i'd say you could get a set of K20A coils in the USA for about $100, there are lots of honda's over there. Check with a wrecker.
Old Jan 1, 2010, 08:22 PM
  #34
Old Jan 3, 2010, 09:51 PM
  #35
Old Jan 4, 2010, 06:07 AM
  #36
awdboosted's Avatar
Originally Posted by norcalSRTrida
did some research on CBR coils, and looks like they need a resistor-type plugs w/ removable screw-in tops...
any recommendations for that? lol
EDIT: nvm, grab ahold of some Denso irid's if going CBR coils.
Yes.. Good Find..
You need to use a resistor type spark plug on Coil on plug systems.
am i able to use these type of coils on a wastespark setup using a CDI box? .
You need to set them up as wastedspark. so 1/4 and 2/3.
Old Jan 4, 2010, 09:01 AM
  #37
Old Jan 4, 2010, 12:06 PM
  #38
JC evo1's Avatar
well im starting my cop build...ordered 4 300m coils yesterday for 30/each. $120.
ordering 4 toyota connectors (5.xx/each) and 8 terminals. thatll total out to about $25 total.
will order 20ft of tefzel military-spec wiring (.22/ft) and will wire it up for about 150$ total. thats about 1/2 the price
can someone explain how this guy on ebay is selling a complete plug and play kit for $165? must be usung 2nd hand coils or getting a killer deal somewhere. http://cgi.ebay.com/ebaymotors/ws/eB...m=260289954746
Im thinking of ditching my leads and stock coil pack (evo1) and running the MSD DIS-2 with this kit, i should have no problems right?
Old Jan 4, 2010, 01:42 PM
  #39
Old Jan 8, 2010, 02:10 PM
  #40
Silver Sponsor
SpoolinUp's Avatar
This kit isn't CDI. Won't work on the EVO 4-7 because DSM's use slightly different ignition trigger signals.
Your EVO 1, however, will like it. I used to make these back in the day! Adapting on a CDI will take a bunch of extra wiring but nothing groundbreaking.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Oct 26, 2011, 03:19 PM
  #41
akinnear03's Avatar
Is there any how to instructions on the wiring or can someone pm me with some
Old Oct 26, 2011, 11:22 PM
  #42
My03evo's Avatar
Ditto, I have a COP kit and msd dis 2 setup but I just need to know which wire is which at the wiring harness on the evo 8 coil harness plug....power...ground...signal?
Old Dec 30, 2011, 07:31 AM
  #43
mrb00st's Avatar
same? i have coils, just looking for a wiring diagram and cant find one anywhere
Old Apr 12, 2012, 01:33 AM
  #44
kid_19440's Avatar
Coil on plug
So I have been reading all the COP threads for weeks. I bought a set up for pretty cheap from ebay. The guy was running this on a GSX which now I realize does not run on wasted spark like our Evos do. I am going to take it apart and re-wire it. My question is will I absolutely need to run the CDI box with the 300m coils ( part number UF269)?
and the order our spark plugs are set up are (1-4) + ( 2 - 3) but where will I get the connector that connects the coils to the car it self? The GSX has a different connector all together but still only three wires.
Any suggestions on that?
Kid
Evo4 Germany
Old Apr 27, 2012, 09:00 PM
  #45
shadovarian's Avatar
What I would like to know is the benefit of the COP setup for our cars and at what point the stock system on the 8s and 9s becomes overburdened
Quick Reply: DIY COP. anything to worry about when selecting coils?
