greddy rs res.b.o.v. adjustment...
I had Greddy RS, I did single spring mod, drove it for a while, I start hearing flutters, eventually the diaphram ripped. Flutters is not good, I went with APS bov, it never flutters, even at lightest partial throttle, even bettter than stock IX dv.
Just installed a greddy rs rec.b.o.v and i was told to set the spring pressure on a hard setting but the release doesn't start to happen only when i'm above 13 psi or more and get the flutter sound after i hit 23 psi part throttle..Is this normal cause im not wot or is the spring still hard?also how much boost will it hold doing the single spring mod....
I am now using a Synapse BOV and it works just as good as the OEM unit and wow it just doesn't leak
Thanks for the info but i'm gonna use the greddy till spring and i will be adding a tial 50mm vented to atmosphere with speed density and some added goodies..
b16a95eg
Feb 22, 2013 01:37 AM
