pvc valve
Old Dec 30, 2009 | 07:30 AM
aleEvo's Avatar
pvc valve
what happens if I remove mine pvc valve? how many vents I must leave overhead?
Old Dec 30, 2009 | 07:36 AM
rgeier11's Avatar
You will need a catchcan to replace the PCV.
http://www.perrinperformance.com/pro...ank?category=4
Old Dec 30, 2009 | 07:37 AM
sktng22's Avatar
does removing the pcv valve and getting rid of most of the emission parts do alot for the car or no?
Old Dec 30, 2009 | 10:44 AM
barneyb's Avatar
Back in the early 70's when emission laws started to have teeth, engines suddenly had half their former horsepower and sometimes had so many vacuum hoses the engines disappeared beneath them. So, what to do about this terrible situation? Well, the answer seemed simple enough, just tear off those hoses.
That was hardly enough, the engines had been changed in more basic ways – smaller valves, smaller cams, lower compression ratios and restrictive catalyzed exhausts. But, still the myth lives on – the road to more horsepower is through removing emission equipment and vacuum hoses.
Old Dec 30, 2009 | 02:50 PM
MitsuJDM's Avatar
You NEED to keep the PCV if you're going to still recirc it to the intake manifold.
If you're going to run both the breather and PCV to a vented can, then that's fine.
Using the vaccum of the intake and intake maniofld is nice to help "pull" the oil vapors out. You just need to use a closed catch can (one with a breather on top) and make sure it's baffled.
Old Dec 30, 2009 | 04:32 PM
Murf's Avatar
A friend of mine uses an air line vapor remover between the PCV and intake manifold. That works well.
Old Dec 30, 2009 | 04:42 PM
MitsuJDM's Avatar
True. I used one of these before. I ended up buying a bigger, real baffled catch can because I have to empty the small air line vapor remover so often. I still use a simple clean fuel filter for the breather side.
kobi2002
Mar 25, 2016 03:53 AM
skred
Jan 9, 2008 07:16 AM
w8lifter21
Nov 13, 2007 07:55 PM
rodman
Mar 19, 2006 06:22 PM
StreetSleeper8
Lancer Engine Tech
10
Dec 3, 2005 05:33 PM
Quick Reply: pvc valve
