Rebuilding...OEM part list help!
I blew up my 05 evo in September and finally getting around to rebuilding. I have made a list of OEM parts that im gonna replace but need you all to look over it and see what i am missing so i can make one order from Mitsu instead of 10...
Idler Pulley
Idler Pulley bolt
Serpintine belt
Tensioner
Thermostat
Thermostat housing gasket
Water pump assembly
Front cover lower
Front cover upper
Tensioner pulley
Front crank seal
Rear main seal
Rear main seal retainer
Oil pump
Oil pump pickup
Tensioner arm
Valve cover gasket
Head gasket
Exhaust mani gasket
Intake mani gasket
Timing belt
Cam seals
Thanks for the input guys
Idler Pulley
Idler Pulley bolt
Serpintine belt
Tensioner
Thermostat
Water pump assembly
Front cover lower
Front cover upper
Tensioner pulley
Front crank seal
Rear main seal
Oil pump
Oil pump pickup
Tensioner arm
Valve cover gasket
Head gasket
Exhaust mani gasket
Intake mani gasket
Timing belt
Cam seals
- Balance Shaft Belt & Pulley/Tensioner - Unless you have deleted that.
- Engine Rebuild Gasket Kit
- Oil Pick-Up Gasket - MD183240
- Oil Pump Gasket - MD322521
- Oil Filter Gasket - MD322522
- Water Pump Gasket - MN137262
- Oil Return Pipe Gasket - MD194403
- Gasket - MD363254
- Oil Return Pipe Gasket - 1226A002
- Gasket - MD329503
- Air Outlet Fitting Gasket - MR281085
- Oil Seals - MD343563/MD343565/MD359158/MD365697/MD372536
- Exhaust Manifold Gasket - MR323654
- Exhaust Fitting Gasket - MR299686
- T/C Gasket - MR404547
- Intake Gasket - 1540A019
- Head Gasket - mn155760
- O-Ring - MD041021
- Oil Drain Plug Gasket - MD050317
- O-Ring (9) - MD075834
- O-Ring (10) - MF660063 (2)
- Union Nipple Gasket - MF660064 (2)
- Governor Pipe Packing - MF660065 (4)
- Valve Stem Seal Intake - MD306079 (8)
- Valve Stem Seal Exhaust - MD307343 (8)
- Seal Washer - MR497720 (2)
- Valve Cover Gasket - MD340535
Do you need a new oil cooler? What happened to the old motor? They say to replace them when rebuilding, especially if it blew up and got shavings/debris in the oil. It stays in the cooler and will ruin a new motor.
The aftermarket ones seem to be right around the cost of a new OEM one. If you do a new one, go with aftermarket, they have more rows/cooling efficiency.
I'd buy a used OEM one out of the part out section or something, save a ton of money.
Actually, I'm seeing that the STM oil cooler is very reasonably priced:
http://www.streettunedmotorsports.co...proclassic.htm
Edit: Used Oil cooler here:
https://www.evolutionm.net/forums/sa...condensor.html
real fast
Apr 15, 2016 05:28 PM
FS[Northeast]: FS-Lots of Evo 8- parting out everything!
2e0v0o3_8
45
Apr 7, 2016 11:02 AM
real fast
Feb 9, 2016 06:59 PM
MJ23FE
Jan 25, 2010 05:10 PM
