Trans issues...
Trans issues...
I have issues on my first start on cold days, Hold the clutch in, start the car when I release the clutch it is if the clutch is engaged and it stalls out immediatly when releaseing the clutch, now when I start the second time its fine, I still feel it grab a bit, but it does not stall out.
I'm having a hard time comprehending what you're saying. Are you saying that if your car is in netraul, depress the clutch and try to select a gear the car stalls? If this is the case, you can try adjusting the clutch pedal but that sounds pretty bad. Usually, you can get away with just adjusting the clutch if you only feel the car nudge foward. Not uncommen in Evo's with aftermarket clutch's.
One thing you can try, again, if I'm understanding you correctly, is if in frist gear, at a standstill with the clutch depressed on level ground, rev up to redline, and if you feel the car move foward even a few inches, your clutch is dragging, same reason you would feel the car nudge when selecting a gear from neutral.
My father had this problem with his Evo. Turns out, his "bone stock" Evo had an aftermarket clutch. He had a stock clutch installed at it works 100% now.
Welcome to Evo's
Welcome to Evo's
Depending on how cold it gets, if its anything like Minnesota here, It could just be the fact that your tranny fluid is so thick from being cold. My car does that so I have to feather the clutch on Initial start up when its in the Negative degrees up here
MitsuJDM, its in netraul, I will explain.. With the car in netraul, I press down on the clutch, start the car, as I am releasing the clutch slowly I feel it start grabbing and it stalls out, now if I just "pop" the clutch (release it quickly) it grabs for a second but the car stays running. Again this is all while the trans is not in any gear. Its really pissing me off, from what I know it has an Exidi Twin disc clutch, I just got the car about two weeks ago, and I really don't know what to think at this point. Also I makes alot of chatter when the clutch is released.
b16a95eg, what do you mean? the weather has been in the 20's, not really in the Negs... but below freezing. I dont know what kind of tranny fluid, or gear fluid is in the car, it has been only two weeks since I got the car.
Fireescape
Jul 4, 2016 11:18 PM
detroit pistins
13
Dec 19, 2013 10:43 PM
drifthobo
Nov 24, 2013 04:58 AM
