Which cam shaft ?
Which cam shaft ?
Hi...
What is the best & highest lift Camshaft i can use for EVO 9 with 67 turbo and 9200 rpm
cosworth
Intake duration "280" deg Intake lift 11.6mm
Exhaust duration "272" deg Exhaust lift 11mm
Kelford
9-TX272 Camshaft Set
272 Duration 11.00mm Lift. Suits 400HP+ street or strip applications
9-TX280 Camshaft Set
280/276 Duration, 11.50/11.00mm Lift. High HP Racing cams
9-TX288 Camshaft Set
288/280 Duration, 12.00/11.50mm lift. High HP drag racing camshafts
GSC
S2 Specs: Intake 278 11.2mm / 274 11mm
S3 Specs: Intake 280 11.70mm / Exhaust 280 11.70mm
Regards,
mnf
cosworth
Kelford
GSC
Regards,
mnf
There is no "best". Searching will provide you with better information then asking such an open ended question. Read around - See what cams people have used with their setups and the ending results.
In the end - I would figured you will end up with the BF272's or the GSC s3's.
if u buy hydraulic cams they should. solid cams are for solid lifters. Just wondering anyway, are u gona be at like 700+ whp? because if ur not and u want to actually have a normal driving car on the road id go with s2 cams or kelford 272s. anything past those is like terrible idle and for very high hp applications.
Chris@nolimitmotors
Evo 'For Sale' Engine Internals and Drivetrain
400
Jan 26, 2017 08:25 AM
Moore Auto
Oct 24, 2012 01:33 PM
Gary@MellonRacing
Sep 25, 2010 04:01 PM
erioshi
Mar 29, 2010 03:39 PM
Edo Performance
17
Jun 21, 2007 12:21 PM
