Exedy twin owners only please!!!!
Old Jan 6, 2010 | 11:03 AM
artevo9's Avatar
Are you talking vibrating noise or pedal is vibrating? I have rattling noise everytime I press down clutch pedal, most of time only on 1st gear.
Old Jan 6, 2010 | 12:18 PM
compscibOi's Avatar
No vibration here. The clutch does make a lot of noises, but no vibration issues you describe. Who installed it?
Old Jan 6, 2010 | 01:20 PM
4u2nvme's Avatar
Its a bleeding issue. It needs to be bled. Mine did this also
Old Jan 6, 2010 | 01:21 PM
4u2nvme's Avatar
Its best to have Mitsu do it with their machine.
Old Jan 6, 2010 | 06:43 PM
wizzo 8's Avatar
Originally Posted by Boltz.
Warning: This post may be completely useless.
I have the exedy twin and do not have the problem you are experiencing. Although I am having a brain fart and can't come up with what I think I have to say, I recall someone having a big problem with their clutch which was forewarned by the same symptom you have. Because I can't figure out exactly what it was that I read, you should probably take this with a grain of salt and ignore me, but I would spend a good amount of time searching on here and see what you come up with....
Hey, I warned you! Hah. GOOD LUCK!
Are you talking about that Guy that had the throw out bearing in crooked? He saw it threw the inspection hole
Old Jan 6, 2010 | 07:02 PM
wizzo 8's Avatar
Originally Posted by tscompusa
I don't remember mine ever vibrating either. you didn't accidently put the clutch disc in the wrong order did you? The only thing I can complain about for the exedy twin is it makes some wierd *** noises sometimes. it howl's and does all kinds of **** when downshifting very nice clutch though for a daily driver with mid/high hp.
you should put car on jackstands and follow TRE's clutch adjustment procedure. http://www.teamrip.com/clutch_pedal_...ment_info.html
Mine makes that howl noise on downshifts also. I kind of like the noise
Old Jan 22, 2010 | 10:42 AM
redhott92's Avatar
agreed. no vibration on mine after 3,000 miles
bluevilevo8
11
Sep 7, 2015 07:30 AM
domantas
Jul 5, 2010 12:42 AM
wizzo 8
12
Dec 2, 2009 08:07 PM
evokw
Apr 6, 2009 10:46 AM
mikiblueeyes
12
Aug 9, 2007 03:13 PM
Quick Reply: Exedy twin owners only please!!!!
