AWD Motorsports EVO 8.5.. " The Bastard " makes 523whp/523Tq on BBK Turbo!!!!
Well we finally got a chance to put our bastardized Evo 8.5 on the dyno tonight.. Ill explain what we have going on in our 2005 Evo.. We have a 4g64 2.4L Mivec motor.. The car is composed of parts from all over the shop, new and used.. Below is a list of basic mods.. The power was made at 30psi...
4g64 Engine w/ Evo IX head..
Cosworth Cams
CBRD BBK Full Turbo @ 30psi
Buschur Double Pumper w/ 1200cc Injectors
E85 pump Fuel
Buschur Ported Intake Manifold & TB
Buschur Ported Exhaust Manifold
Stock 02 Housing
DC Sports Downpipe / Test Pipe
AWD Mini Battery Kit
AWD UICP & LICP
Stock fuel Rail
Stock Ignition
Stock Ecu w/ MAF Tuned By: Diiirk
Cosworth Cams
E85 pump Fuel
Stock 02 Housing
AWD UICP & LICP
Stock fuel Rail
Stock Ignition
oh suuuureeee.... its all about size
jk,
awesome numbers Mike..
any chance we will see some drag times like the guys were asking for? since CBRD doesnt do the drag strip
Thanks again for seeing what you could do... Ill make sure we get you the new larger version when its released (or a few weeks before its released)
Cheers
CB
jk,
Cheers
CB
jk,
Cheers
CB
jk,
Cheers
CB
Mike
I'm actually looking at building a 2.3L around my BBK full right now. I'm going to be running pump gas (93) only. I see you're running a double pumper with E85. Are you running stock fuel lines or did you replace them? I'll be in touch with you again on Monday.
