Ryu's hunting for 9's on the Stock Block
#63
still don't quite get it. The turbine wheel is same size, like you said, on the black it will spin slower, spinning slower will evacuate less exhaust gas through the turbine, thereby creating more back pressure. The only way the black would have less backpressure is because the wastegate can open more due to less air having to flow through the turbine to flow same lb/min.
So you're probably right, the black will have less backpressure, but thats because it can afford to let more air out the wastegate I'd theorize less air is getting through the turbine though. Please correct me if i'm wrong.
#64
Whats the turbine dimensions on the black/red ?
#70
Unfortunately it will not.
I feel the same way. The biggest hurdle will be when the tune is completed and the motor is still holding strong. Once the power is there it should only be a matter of a clean pass down the track.
#72
i know that the fp black should be quicker than your old red, maybe 3,4 th tens of a second or like 50-100whp more than the red. But if i were u, i would get the hta 3586 kit. That's just my opinion
#74
Possibly. I just don't agree with the $4xx price tag....
