Garrett GTx-R turbos/comp wheels.
Old Jan 19, 2010, 12:06 AM
Extreme Tuners's Avatar
Originally Posted by 03whitegsr
An updated 61 sounds interesting. Similar 10% gains as the GT42 stuff?
The 61mm compressor wheel seems great but inside the old 0.70 compressor cover surging. old 61.4mm is actually 62mm now.
Old Jan 19, 2010, 09:39 AM
spdracerut's Avatar
Have pics?
Old Jan 20, 2010, 12:04 AM
tech b's Avatar
Originally Posted by chuntington101
Hi all,
Has anyone seen the new Garrett GTX-R wheels? i have heard some VERY good things about them. Here are some specs nicked form the Garrett website.....
10%+ Gain in flow over traditional GT compressor wheel designs
10%+ Higher pressure ratio compared to traditional GT compressor wheel designs
Forged, fully machined wheels (billet) for expedited release
11 Full-blade design for improved efficiency and ultra quiet operation
Here is the info on Garretts wesite: http://www.turbobygarrett.com/turbob...ochargers.html
Think they have the GTX-42R and GTx-45R turbo avaliable. GT35 should be out later this year.
Cheers
Chris.
I've seen quite a few of them in person at a custom turbocharging shop here in the Phoenix area. I told the owner of the place I was interested in buying/upgrading a IX, but didn't think the big ones would be appropriate. He said that they could mix and match according to my application and had a few in stock for me to look at. I'm thinking of dumping my rx-7 and pulling the trigger. I keep seeming to run into guys with tons of money in paint and wheels cheap turbo setups.
here's some pics
http://www.turblown.net/store/index.php?productID=64
Old Jan 20, 2010, 04:57 AM
chuntington101's Avatar
here's some pics
Yeah i saw that on thir website... They also do some very nice T4 and T6 inconel heat shields!
Old Jan 20, 2010, 10:10 PM
tech b's Avatar
Yeah they have a lot of nice stuff. Maybe I will just wait til the 35R version comes out..
Old Jan 21, 2010, 01:04 PM
Mark_L's Avatar
I have a 1G with a standard 4202R with a 1.01 exhaust housing, It takes about 6.2K to get it up to 40 psi from a 3rd gear roll on. I like the thought of less boost to make the same power and the benefit of decreased spool time. Before I upgrade I wish I could see what the difference is in spool with just a turbo swap, without compression changes. Also I have not seen a 74mm compressor map released yet, has anyone seen it??
Old Jan 21, 2010, 01:39 PM
FathouseFab's Avatar
40psi by 6200 is pretty good imho, whats the engine setup like? How much power does it make?
Fathouse
Old Jan 21, 2010, 01:56 PM
EvoM Moderator
scheides's Avatar
What up Mark! wtf are you doing on the interwebs?!?!
Fathouse
His 1G put down whp in the mid 700's at our fall dyno day, maybe like 35psi IIRC? His DD evo casually put down 520 w/ a FP Red on it. This guy does not eff around!
Old Jan 21, 2010, 05:34 PM
Mark_L's Avatar
Fathouse
It's a 2.3 stroker. 787whp 37psi peak settled out to 35psi up top.
Old Jan 21, 2010, 05:36 PM
Mark_L's Avatar
I know it’s shocking that I’m posting. It’s just that I’m excited that there is finally cool turbo technology in larger compressor wheels.
Old Jan 21, 2010, 06:01 PM
03whitegsr's Avatar
Mark, what kind of manifold are you using?
Old Jan 21, 2010, 07:21 PM
Hiboost's Avatar
The 61mm and 66mm wheels seem inticing, I'm thinking about upgrading the internals in the Bolt on Garrett GT3076r housing with .94 AR twin housing so I'm sure if it would be a surge monster or not. Maybe with the right portwork on the hot side it would be ok.
Inducer sizes:
GT3076r = 57mm
HTA35r = 59mm
35r = 61mm
I think the exducers are quite a bit larger on all of those numbers though which makes a difference as well.
Old Jan 21, 2010, 08:47 PM
Mark_L's Avatar
Magnus non- race for the intake manifold and Shearer for the header.
Old Jan 24, 2010, 09:21 AM
tech b's Avatar
So I've been told Garrett will have their billet 35R out maybe as soon as early summer. I'm shooting for that unit.
Old Sep 15, 2010, 02:56 AM
3gEclipseTurbo's Avatar
Anyone do testing to see the difference in spool between the old 4294r vs new4294r and for the old vs new 4202r? I read someone saw a 400-500rpm quicker spool on the gtx-r beleive that was 4202r vs 4202r
Quick Reply: Garrett GTx-R turbos/comp wheels.
