Garrett GTx-R turbos/comp wheels.
Old Jul 15, 2011, 03:10 AM
  #31
testa corse's Avatar
any updates for the GTX?
Old Jul 15, 2011, 05:50 AM
  #32
RSMike's Avatar
We will be testing the GTX3076 vs the 3076 shortly.
It's on the way over from the USA (thanks Potter @ MAPerformance) and we'll be testing it on a SR22 that has made 530whp maxing out the compressor @ 22psi.
Hopefully we'll pick up some more power, but i'm not sure if the exhaust side will be holding the system up.
The car is running 0.82 T3 TS exhaust housing.
Time will tell!
Old Jul 17, 2011, 02:05 AM
  #33
im curious to see the power gain diffrences
Old Oct 23, 2011, 12:58 PM
  #34
RSMike's Avatar
We have starting testing of the GTX3076, With a 0.82 T3 TS housing.
This is on a EJ20 with dual VVT heads.
peak boost was being made @ 4500rpm with VVT turned off, Now with VVT on we are making 18psi boost @ ~3600rpm.
390whp @ 18psi at only 7000rpm.
I will try to get pics up this afternoon.
This testing is on a stock block, with worked heads/cams etc.
We will be building an EJ25 and be testing the GTX3076 vs 7670.
Cheers, Mike
PATRICK B.
330
Dec 2, 2018 07:31 PM
03whitegsr
23
Nov 19, 2016 10:06 PM
FreakEVO
Nov 5, 2016 02:55 AM
riceball777
21
Dec 12, 2015 07:18 AM
onyx1121
16
Oct 25, 2009 10:34 AM
Quick Reply: Garrett GTx-R turbos/comp wheels.
