Megan downpipe gasket question?
Old Jan 7, 2010 | 02:36 PM
GG06MR's Avatar
What gasket should I be using for the connection of the O2 housing to the downpipe? I've got a IX MR and I recently crushed the bottom of my Megan downpipe, which had the older style flex section in it. I ordered a replacement Megan downpipe(ACD version) to replace it, but it only had one flat gasket in the box, so I reused the donut gasket on the O2 housing that was used for my old downpipe, and put the flat gasket down where the downpipe bolted to the test pipe. At this point it runs perfectly fine with no apparent exhaust leaks, but I am wondering if I was supposed to use that flat gasket at the O2 housing, because the donut gasket didn't fit the new downpipe nearly as well when I bolted it up, and the new downpipe won't clear either of the lower tie bars without using longer bolts and washers to space the tie rods down lower. Any help clearing this up will be greatly appreciated.
Old Jan 8, 2010 | 04:50 PM
GG06MR's Avatar
Anyone...anyone? Beuhler?
Old Jan 8, 2010 | 05:20 PM
evokid511's Avatar
the donut gasket goes on the o2 housing where it connects to the dp... its a little hard to get on there but thats where it goes... the flat gasket goes where you have it between the test pipe and dp
Old Jan 8, 2010 | 05:29 PM
Kracka's Avatar
Reuse the stock gasket thats on your o2 housing.
Old Jan 8, 2010 | 05:37 PM
GG06MR's Avatar
Perfect. Thanks everyone for confirming that I'm not an idiot. I'll go get some longer bolts and washers tomorrow so that I can bolt my lower tie bars back up.
Old Jan 8, 2010 | 06:53 PM
awd2gen's Avatar
lower tie bars are over rated.
Old Jan 8, 2010 | 08:01 PM
GG06MR's Avatar
I'm not sure if that's the case with aftermarket lower tie bars, but I must say that it was pretty easy for me to get the OEM tie bars to flex.
Svendiesel
Jun 7, 2013 09:32 AM
17579EVO9MR
13
Oct 26, 2010 01:53 PM
drb
14
Sep 4, 2009 12:06 PM
dbsears
11
Sep 21, 2007 09:20 PM
fostytou
Aug 20, 2007 09:54 AM
Quick Reply: Megan downpipe gasket question?
