Any engine builders ever added deck height to 4g63 or 4g64?
Old Jan 14, 2010 | 10:05 AM
  #31
GotWheelHop's Avatar
Originally Posted by R/TErnie
106mm stroke @ 8k is 28.2m/sec NOT 14.1
an equivalent piston speed with a 88mm stroke would happen at 9637RPM
Ah crap, forgot to add in that you have 2x stroke length per revolution.
Old Jan 14, 2010 | 01:18 PM
  #32
R/TErnie's Avatar
figured
Old Jan 21, 2010 | 05:32 AM
  #33
bsh's Avatar
bsh
Interesting... How do they seal the spacer to the block?
Is it easy to find a longer timing belt?
Old Jan 24, 2010 | 07:52 AM
  #34
Conrad's Avatar
Its been done many times on Rb26 engines. A company called OS Giken in Japan make the kit and it takes the RB26 block to an RB30 block. The CNC'd spacer plate it bolted to the original block and a one piece top hat liner is installed into each cylinder. I have been told by somebody who used this set-up that issues can occur as the material for the block and the material used for the spacer plate heat up and cool at different rates and ultimately some distortion occurs causing further problems.
Old Feb 9, 2010 | 10:16 PM
  #35
MitsuJoe's Avatar
Does anyone know of anyone who has successfully sleeved the 4G63/4G64?
I was looking to do it and sleeves are available. I just decided to get another block.
Old Feb 9, 2010 | 10:30 PM
  #36
slow/ass/rs's Avatar
talk to fftec or english racing they are the only ones that i know that have sleeved 4g63 motors
Old Feb 15, 2010 | 06:31 PM
  #37
burnzy's Avatar
os giken does such a kit for the RB26
Old Feb 15, 2010 | 08:20 PM
  #38
R/TErnie's Avatar
I think most of the kit is doable...and the timing belt is the real only issue. I bet we could get Gates to make a custom belt.
Old Oct 27, 2013 | 10:22 AM
  #39
drumnbassbboy's Avatar
Resurrecting an old thread.
I am no engine builder, so bare with me...
Even if you were to make a spacer plate, wouldn't the true limitations of such an idea be limited to the crankcase dimensions and not the block/deck height? (i.e. How much longer of a stroke you could actually fit to meet the new block/deck height? This is essentially what the stock 4G64 does. Increases the stroke by 12mm (crankshaft). Half of the stroke is seen at BDC (6mm). The other half of the stroke is seen at TDC (6mm). The longer stroke is taken care of at TDC by the additional 6mm of block/deck height (imaginary spacer plate).
What are the dimensions of the crankcase (4G63/4G64)?
How long of a stroke (mm) do you believe you could fit into the crankcase (4G63/4G64)?
I know the BC 2.6L kit utilizes a 106mm crank for the 4G64 block / 4G63 head hybrid motor.
http://www.briancrower.com/makes/mit..._stroker.shtml
"All new 4G64 block with 4G63 head recently added... 2.6L w/ 106mm stroke."
What are our crankcase limitations?
If anything, the spacer plates can give us some better rod/stroke ratios and even more displacement.
Last edited by drumnbassbboy; Oct 28, 2013 at 07:40 AM. Reason: Slept on my original thoughts.
Old Oct 29, 2013 | 11:04 AM
  #40
Anyone?
I know the suitcase handles on the 63 would have to be clearanced for a larger crank. Beyond that, what other dimensional limitations are there?
Old Oct 29, 2013 | 12:22 PM
  #41
JohnBradley's Avatar
Depending on the rod length and beam dimensions it will be more than the girdle that needs clearanced. The bottom of the sleeves will need notched which is pretty standard but I would presume it will need the webbing near the balance shaft opened up, and maybe far enough its into the block.
When I did the 162mm aluminum rod 2.2 (94mm) 4 years ago it was notched into the oil galley and then we had to have the galley "sleeved". Very long rod and wide as well in that case but it barely wanted to clear with the 94mm crank. Steel rod and a 106 with a spacer could run in to similar dimensionality issues though the kit is out there so I presume it fits for the most part.
On LancerRegister a few years ago there was a deck plated 4G64 for sale. It was built by an engineer at Triumph as I recall. He added 12mm of deckheight and ran a 162mm rod with a 100mm crank.
Old Oct 29, 2013 | 02:51 PM
  #42
03whitegsr's Avatar
Rod ratio does very little for peak piston acceleration (force on rod, piston, and wrist pin). What's the point as adding a ton of extra deck height and running a 2:1 rod ratio doesn't change the fact you are still trying to accelerate the piston 100+mm at a high rate. It's a couple percent difference on peak forces from like a 1.6:1 rod ratio to a 1.8:1 rod ratio.
R/TErnie
80
Jan 7, 2021 03:46 PM
11secEVO7
20
Jan 28, 2017 11:27 AM
trinydex
35
Sep 6, 2015 09:11 AM
JohnBradley
Jun 26, 2010 11:11 AM
dsevo
218
Feb 12, 2010 11:25 AM
Quick Reply: Any engine builders ever added deck height to 4g63 or 4g64?
