Broken motor mount
Broken motor mount
Hey guys I was involed in a accident and just when my car is about to be done I realized that my motor is slanted and it look like the mount is messed up around the block and would like to see a picture of the block where the bracket is mounted on block. If it's screwed into the block or if it's part of the block. The mount that I'm talking about is the pass side by the cam gears. Any info would be great I won't be able to get the car out of the shop untill thur-fri so I won't be able to rip the car apart untill the weekend but would like to get a idea on what I have to order/fix. Hopefully not have to replace the block
Here is a link to a pic of an AMS 2.1 motor if it helps any
http://www.dynotechonline.com/store/...-A0174B-1A.jpg
Posting pics of where yous is bent at may help also
Thanks I know about the 3 bolts I just wasn't sure if the 2nd piece of the mount was bolted to the block or if it's part of the block. I don't have any pics yet because I won't have my car back untill Thursday or Friday. From just looking at it all I could really see is the mount where the 3 bolts are is touching the timing belt cover. So I assumed that the second part that blots to the block is broken. And also I purchased the mishimoto aluminum shround with dual fans and one of the fans is touching the wastegate actuator so it looks like the motor shifted/slanted to the pass side and forward
FS[MidWest]: Stock running long block 90k
Dshen
Apr 13, 2016 08:35 AM
