ACD to non-ACD T-Case
Might as well sell yours and get a Non-ACD case, it would be cheaper. I'm not too sure non-acd parts would work in an ACD case. I just swapped cases, sold my ACD case, pulled the line and pump off, etc.
- Replace the acd clutch packs with the viscous coupler, place the lsd in the carrier and change the acd hat for the 03-04 hat.
That is a basic run down from what I was told by english racing....it can be converted.
I plan to have mine converted but im going to pull my current tc and send both my spare 03-04 case to shep and have him do it and re-shim everything to his specs + the additional mods he does to his TC builds. My ACD case has a good ring/pinion and the LSD - the 03-04 case i have has the hat and VC i need so I figured going that route im going to have a shep built tc in the process.
to me its just another thing to break and at 67k miles i have had (1) acd pump failure and looks like the new pump I had installed at 59k is starting to go bad, 3 lights intermittently come on again.
figured in the end i free up some space, shave some weight and get a much simpler setup and less headache. Also why i plan to convert the car to non-abs as well - time to make life simple.
boostawd16
11
Aug 29, 2016 01:40 PM
WTB[MidWest]: Flywheel, non-acd tcase, transmission
evo8lento
10
Aug 24, 2016 11:07 AM
desertsoldier22
Feb 17, 2016 08:51 AM
Ian0611
Dec 17, 2015 02:27 PM
